Moment of Inertia of an Infinite Rod with Non-Uniform Density?
The discussion revolves around calculating the moment of inertia of an infinite rod with a non-uniform linear mass density defined as A/x^4, extending from x = +b to infinity. Participants are exploring the implications of the rod's setup and the integration process required for the calculation.
  • Participants discuss breaking the rod into small pieces and using integration to find the moment of inertia. There are questions about the limits of integration and the role of the total mass in the calculations. Some express confusion about the linear density and its application in the context of the problem.
The conversation is ongoing, with participants providing clarifications and corrections to each other's understanding of linear density and integration limits. There is no explicit consensus, but some productive guidance has been shared regarding the integration process.
Participants are navigating the complexities of non-uniform density and the implications of the infinite length of the rod. There is mention of a potential misunderstanding regarding the total mass and its relevance to the problem.
chromium1387
A thin rod extends along the x-axis from x= +b to infinity. It has a non-uniform linear mass density of A/x[itex]^{4}[/itex] where A is a constant with units of kg m3. Calculate the moment of inertia of the rod for rotation about the origin.
Well, I know that you have to put the rod in a coordinate system, break it up into small pieces, take the sum of the those, take the limit as n goes to infinity, and integrate.
So, I basically want to [itex]\int[/itex]x^2dx because the word "thin" suggest that the y-coordinates do not matter. I understand that by breaking the rod into small pieces and choosing one, I have a [itex]\Delta[/itex]m which I need to relate in terms of dx. I can do this using using the [itex]\frac{\Delta m}{M}[/itex]=[itex]\frac{\Delta x}{A/x^{4}}[/itex], where [itex]\Delta m[/itex] is my piece of mass, M is the total mass, [itex]\Delta x[/itex] is my small width, and then A/x[itex]^{4}[/itex] is my linear mass density. But I don't really know where this b and infinity and limits of integration come into play. :( If any can help me get started, that would be awesome!
hi chromium1387! :smile:
yes :smile:
except that's not the way linear density works …
the mass of a length L is linear density time L, so the mass of [x , x+∆x] is A∆x/x4 :wink:
you're adding (integrating) the moment of inertia for every [x , x+∆x]
so you start at one end of the rod, and go to the other … ∫b
Ohhh.. My bad. Silly algebra mistake.
And that makes sense. I'm just used to placing one end at the origin.
Sooo, after I integrate and everything, I get [itex]\frac{MA}{b}[/itex]?
Thanks for your reply!
erm :redface: … why do you keep talking about M ? :confused:
apart from that, yes :smile:
I don't know.. haha. It's just incorporated into the density, right? :P
it doesn't exist! :biggrin:
okay. :)
  • · Replies 21 ·
