New Reply
A flat-torus as the geometry of space-time
Share Thread Thread Tools
Apr15-12, 12:08 AM   #1
New thread continuing a topic raised in 'Physical Space Properties Question'
Quote by Nabeshin
Quote by zhermes
Quote by Nabeshin
Quote by neginf
Could physical space have a different topology than the usual R^3 ?
Yes, the simplest of them being a 3-torus.
How does this interplay with measurements of flatness? [...]
The 3-Torus is actually spatially flat everywhere, so the measurements of flatness only support such a theory. One idea of how to place limits are whether or not we see radiation running along the compactified dimensions of the torus, i.e. multiple images of the same objects. This of course gives you only an lower limit to the 'radius' of the torus, but I don't know of any actual experimental bounds on this from CMB data, for example.
Okay, so I saw on wikipedia that you can have a 'flat torus' --- at least a 2 dimensional torus inbedded in 4-space. So you can also have a 3-torus, that's flat?
And would time just be added on as an additional, orthogonal dimension?
I'm a little confused about how/why this is considered flat. In the same wikipedia article, it says that a (2)cylinder is also flat---this is news to me. The analogy they make is that bending a flat piece of paper into a cylinder doesn't require any stretching/deformation of the paper. Okay. And I also realize that a 2cylinder would still have triangles whose angles add to 180 degrees... etc etc.
These things definitely aren't true for the standard 2-torus in 3D; I would have assumed the 3-torus was the same.
My understanding of differential geometry is rudimentary--only what I've gleamed from attempts at GR. I have no experience with 'topology' per se. None-the-less, equations would be welcome.
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Front-row seats to climate change
>> Attacking MRSA with metals from antibacterial clays
>> New formula invented for microscope viewing, substitutes for federally controlled drug
Apr15-12, 05:40 AM   #2
mfb
Newcomer 2012
Recognitions:
Homework Helper Homework Help
The metric on this 2-torus in 3D-space would not be the regular one you have in our three-dimensional space. To see this, look at the lines in images like this one. They span a grid of equidistant lines - but in our 3D-space, they are not equidistant.
You can consider the 3-torus as three-dimensional cube, where the faces are connected via "magic".
Apr16-12, 01:25 AM   #3
Recognitions:
Quote by mfb View Post
It's not really magic. It's just counter-intuitive. General Relativity simply doesn't require that our 3+1 dimensional space-time be embedded in a higher-dimensional space-time for it to be connected.
Apr16-12, 07:37 AM   #4
Quote by Chalnoth View Post
Sorry, could you elaborate a little on that? How does the embedding relate with the connection?
Apr16-12, 07:45 AM   #5
Recognitions:
Quote by zhermes View Post
When people think of a connected space-time, they usually think of a space-time that wraps back on itself in higher dimensions. For example, the surface of a sphere is a two-dimensional curved surface that wraps back on itself embedded in three dimensions. Within General Relativity, we can refer to such a surface without ever referencing any more than those two dimensions of the surface. And so, for example, if we find that our universe has the spatial topology of a 3-sphere, then there wouldn't be any reason to believe that it was embedded in higher dimensions in order to wrap back on itself.
Apr16-12, 08:58 AM   #6
Recognitions:
I think Chalnoth means to say ..."wraps back on itself in three dimensions."
May7-12, 08:54 AM   #7
Okay, so I saw on wikipedia that you can have a 'flat torus' --- at least a 2 dimensional torus inbedded in 4-space. So you can also have a 3-torus, that's flat? And would time just be added on as an additional, orthogonal dimension?
When people think of a connected space-time, they usually think of a space-time that wraps back on itself in higher dimensions. [...]
And then there are projections of moving submanifolds within a flat torus. Makes me wonder: in a cosmological context, what if it's not spacetime that's actually curved? The old idea of spacetime curvature got a boost from measuring astronomical lensing of light, but what if some mass-induced polarization of the medium of quantum transmission is found to be the cause? In recent explorations of "nothing", the zero points of each quantum field allow for much to happen between the level of an absolutely ultimate space, and the level of lepto-quark phenomena.
What would be fun is to find a relationship that emulates what has been treated as "spacetime curvature". The way time appears always to move forward, and how gravity appears always to suck, may point to something about the motion of our massive manifold when projected within a toroidal topology. In such a case, what would it take to make it appear that space is performing a period expansion, or the reverse?
With LHC warming up, and JWST soon to launch... great time to be in the field.
New Reply
Tags
geometry, spacetime, torus, universe
Thread Tools
Similar Threads for: A flat-torus as the geometry of space-time
Thread Forum Replies
is space-time flat or curved over time? Cosmology 7
laying the double-torus flat Calculus & Beyond Homework 2
Conformally Flat Space Time Advanced Physics Homework 10
flat torus embedding in euclidean space? Differential Geometry 13
Spherical Geometry and Flat Geometry Space-Spacetime's Special & General Relativity 0
