Trigonometric form of Legendre equation
The discussion focuses on converting the Legendre equation, represented as (1 - x²)y'' - 2xy' + n(n + 1)y = 0, into its trigonometric form by substituting x with cos(θ). The correct transformation leads to the equation (sin²(θ))y'' - 2y'cos(θ) + n(n + 1)y = 0 for -π ≤ θ ≤ π. A critical point raised is the distinction between derivatives y' in the context of x and θ, necessitating the application of the chain rule for accurate conversion.
  • Understanding of Legendre differential equations
  • Familiarity with trigonometric identities
  • Knowledge of the chain rule in calculus
  • Basic proficiency in differential equations
  • Study the application of the chain rule in differential equations
  • Explore the properties of Legendre polynomials
  • Learn about the derivation of trigonometric forms of differential equations
  • Investigate the implications of variable substitution in differential equations
Mathematicians, physics students, and anyone studying differential equations, particularly those interested in the Legendre equation and its applications in trigonometric contexts.
Jesssa
hey,
[itex](1-{{x}^{2}}){{y}^{''}}-2x{{y}^{'}}+n(n+1)y=0,\,\,\,\,\,-1\le x\le 1[/itex]
to convert the legendre equation y(x) into trig form y(cos[itex]\theta[/itex]) is it simply, set x=cos[itex]\theta[/itex] then
[itex](1-{{\cos }^{2}}\theta ){{y}^{''}}-2{{y}^{'}}\cos \theta +n(n+1)y=0[/itex] for [itex]-\pi \le x\le \pi[/itex]
[itex]{{\sin }^{2}}\theta {{y}^{''}}-2{{y}^{'}}\cos \theta +n(n+1)y=0[/itex] ?
im just a little paranoid this seems a bit straightforward for a past test question
Jesssa said:
hey,
The problem is you are glossing over what ##y'## means. In the first equation it is ##\frac{dy}{dx}## and in the second it is ##\frac{dy}{d\theta}##. They aren't the same thing. You need the chain rule. You can see the correct formulas here:
http://mathworld.wolfram.com/LegendreDifferentialEquation.html
  • · Replies 20 ·
  • · Replies 19 ·
