Why Isn't Momentum Conserved on All Axes in a Bouncing Ball Scenario?
  • Context: Undergrad
  • Thread starter Thread starter ZxcvbnM2000
    Law Momentum
The discussion revolves around the conservation of momentum in the context of a bouncing ball scenario and collisions between two balls. Participants explore the implications of external forces, the law of restitution, and the conditions under which momentum is conserved or not, focusing on both theoretical and practical aspects of these concepts.
  • One participant asserts that momentum is conserved only when no external forces act on the system, questioning why momentum conservation cannot be applied on the y-axis during a bounce.
  • Another participant agrees, explaining that the reaction force from the ground is an external force that affects the momentum of the ball, leading to a reversal of direction upon bouncing.
  • A participant expresses confusion about their restitution formula, suggesting that their system only includes the ball and not the ground, leading to a misunderstanding of the coefficient of restitution.
  • In a hypothetical scenario involving two colliding balls, a participant questions why momentum is not conserved along both the line of impact and the perpendicular axis, despite both balls being part of the system.
  • Another participant challenges the assumption that momentum isn't conserved in all directions, prompting further inquiry into the conditions of momentum conservation.
Participants express differing views on the application of momentum conservation in various scenarios, with some asserting that external forces disrupt conservation while others question the assumptions behind these claims. The discussion remains unresolved regarding the specific conditions under which momentum is conserved or not.
Participants highlight limitations in their understanding of the system boundaries, the role of external forces, and the application of the law of restitution. There are unresolved mathematical steps and assumptions regarding the definitions of the systems involved.
This discussion may be useful for students and enthusiasts of physics, particularly those interested in mechanics, collision theory, and the principles of momentum and restitution.
ZxcvbnM2000
Hello everyone , here we go :
I understand that momentum is always conserved as long as no external forces act on a given system . I also understand that the law of restitution applies to the axis perpendicular to the line of impact between two objects .However i have a problem .
For example . A ball hits the ground at an angle of 45 degrees and bounces up at an angle of 30 degrees.
So from the law of restitution : e= - ( Vball*sin30 - Vground)/(Uball*sin45 - U ground) , the ground does not move therefore Uground = Vground=0 so
e = - Vball*sin30/(Uball*sin45).
My question is , why can't we apply momentum conservation on the y-axis ? Is it because the reaction force when hitting the ground is considered an external force ?
I am very confused please explain :S
Thank you !
Exactly. If you look at the ball itself, its direction reverses when it bounces. So obviously, momentum of the ball is not conserved--it's being smacked by the ground!
If you expand your 'system' to be 'ball + ground/earth', then momentum will be conserved again. (The force between ground and ball would then be an internal force.)
So my restitution formula is wrong and the only thing i have in my "system " is the ball , no ground etc . So it should be e= - V*sin30/(u*sin45) but e can't be negative ...argh ! :S
Let's assume that two balls(m1=m2=m ) collide with one another .
The first ball is traveling at a speed u while the second ball is stationary.The first ball strikes the second one at an angle θ to the line of impact.If the coefficient of restitution is e , find the angle at which the second ball travels after the impact.
What i don't understand in this case is why isn't momentum conserved both along the line of impact and on the axis perpendicular to it as well ? I mean , both balls are part of our system so there are no external forces ?!
Could you please solve this exercise and explain each step thoroughly so i can finally understand ? Thank you very much !
Why would you think that momentum isn't conserved in all directions?
  • · Replies 53 ·
  • · Replies 77 ·
