Shouldn't we see faster expansion without dark energy
The discussion revolves around the concept of the universe's expansion, particularly the relationship between the initial expansion rate at the big bang and the observed acceleration of that expansion. Participants explore whether the observed velocities of distant galaxies can be explained without invoking dark energy, considering the implications of light speed limitations and gravitational effects.
  • Exploratory, Technical explanation, Debate/contested
  • One participant suggests that if the universe expanded faster at the big bang, we should observe faster expansion at greater distances, questioning the necessity of dark energy.
  • Another participant clarifies that the rate of expansion and the velocity of galaxies are distinct concepts, noting that the expansion was initially thought to slow due to gravity but was later found to be accelerating.
  • A participant expresses uncertainty about the relationship between the observed velocities of galaxies and the expansion rate, suggesting that closer galaxies appear to move away faster than expected if the expansion were slowing.
  • Some participants assert that the increase in galaxy velocity with distance is a result of the expansion of the universe itself, rather than being directly linked to dark energy.
  • There is a discussion about the terminology used, with one participant questioning whether "acceleration" is the correct term for describing the increasing rate of expansion over time.
  • Clarifications are made regarding the distinction between the velocity of galaxies and the acceleration of the expansion rate, with participants agreeing that the observed velocities are due to the universe's expansion.
Participants express differing views on the relationship between the expansion rate and galaxy velocities, with some asserting that the two are connected through the expansion of the universe, while others question the role of dark energy. The discussion remains unresolved with multiple competing views present.
Some assumptions about the definitions of expansion and acceleration are not fully explored, and there are unresolved questions regarding the implications of gravitational effects on expansion rates.
KeplerJunior
I understand that before we knew about dark energy we thought expansion would have slowed down since the big bang but we then discovered the universes expansion rate to be accelerating.
My question is, surely if the universe did expand faster at the big bang we would see it expand faster the further away we looked as you account for the limited speed of light so there would be no need for dark energy (ignoring missing mass etc.)
I'm sure I've missed something or got something wrong and that there is an explanation but i just wanted it to be clarified
Space news on Phys.org
Kepler, I *think* you are semi-correct. I believe when we looked out and measured lots of supernovas it turned out that galaxies closer to us were moving away faster than they should have been if the expansion had been slowing. Someone correct me if I'm wrong.
So the velocity of galaxies does increase the further away you look but that's not due to dark energy
The expansion rate itself is what causes galaxies further away to have a higher velocity. The acceleration is actually an increase in the rate of expansion. I'm not sure if "acceleration" is the correct term for a rate of something. The rate is increasing over time, which we call acceleration.
Thanks so just that I'm clear galaxies having a higher velocity is just caused by the expansion of the universe the acceleration of the rate of expansion is not connected to that
Galaxies further away in distance having a higher velocity than those closer in distance is the result of expansion, yes.
  • · Replies 29 ·
  • · Replies 37 ·
  • · Replies 20 ·
  • · Replies 33 ·
10K
  • · Replies 134 ·
13K
