| New Reply |
What's the precise relationship between Mass and Charge |
Share Thread |
| Apr19-12, 06:29 AM | #1 |
Sorry, If I couldn't reach out for the actual meaning of my question. Its my bad english.
Q : What's the exact relationship between charge and the mass? I found that charge never exists without mass. It should have any amount of tiny mass associated with it to exist. So, why is it so? If there is any experimental proof to state me wrong about this, please mention it, because I didn't hear of it anywhere. There is a relationship between matter and energy, right? So, similarly, there must be some relationship between mass and charge. We can find mass without charge, but not charge without mass. Not even in the Hawking radiation above black hole that we find some charge without mass. Why is it So? Why aren't we able to propose a theory for that? If already proposed please let me know it. |
| Apr19-12, 07:33 AM | #2 |
This is a basic element of the standard model of particle physics. Charge comes from charged particles, which have mass.
The lowest mass, highest charged particle is the electron---thus setting a minimum mass-to-charge ratio. |
| Apr19-12, 07:49 AM | #3 |
a Stupid version probably but I feel that charge also has something to associate with, which is yet to be discovered. A field is associated with a vibration ( variations) and a particle is associated with mass. Then also there must be something also associated with charge following the two mentioned. Just like, the matter association with waves following dual nature after light making dual nature. :) After all the whole Universe is made up of matter and radiation (fields)
I may seem stupid, but I think there is a scope for this. |
| Apr19-12, 03:43 PM | #4 |
| Apr19-12, 07:10 PM | #5 |
Why so? Potential energy is something which is possessed because of its position. So, is it the greatness of the position or the presence of the particle that is giving its energy? If its the position, then how is the energy induced into something because of its position? More precisely, what is the body taking or giving with the space that's providing it with something called energy to move over the space. Various reactions cause the release of energy. Its releasing its energy, which means transferring it to something or back to the space while reacting. But, how is this process going on? Does this imply that matter is just a mere, useless player on the stage (space) where everything is done by its position rather than its content? I guess you don't know answer for the reason for this. I think no one knows, but I'd like to state it here. How is this feeling taking place. I know it may seem stupid. But, we can say how we feel something. we can say how we interact with feelings relating to the external world. We see it, analyze it, compare it and enjoy it (I don't know about this part). So, there must be something which causes or atleast explains this function of "feeling the force" part of the matter. I think the Experiments at CERN and LHC may be used to determine this. I'd like to state my belief here. Only certain particles have charge associated with them. I think almost every particle has a charge associated with them. So, there must have been something special or something different in content of the matter which is giving the property of charge to the particle. I'd be pleased to hear, if any (how and what way), a string theory or something similar, deal with this and clear this doubt. I am stating here: after all we discovered atoms so that we could account everything we see with the most fundamental reactions between few particles and explain every phenomena around us with it. When we find still more properties inside the atom, then we explain it using further more basic particles like quarks or leptons. But, the charge exists even with the quarks and leptons. So, there must be something inside these quarks and leptons, probably a pattern or position or something similar, which will explain this property of 'charge carry' confined to that particular particle. There should be some theory and very much necessary to explain this phenomena. We are trying to relate something called Higgs boson, so that we could account for the mass of something, or address why a particle has a mass/ what makes it heavy? ( Justify, if this is wrong) I feel that, when there is a set of multiple properties associated with one single body, then it needs to break down into smaller ones to deal the fundamental of each property and claim it to be their responsibility inside the body. Its analogous to explaining the property of color, taste, viscosity etc using all the different interactions between matter particles. Are we stating something like, its the fundamental property of the liquid that it possesses those property or the same atomic composition explanation we give for both color and taste of the liquid ? Its pretty obvious, isn't it? I guess I am going in an un-orthodox and very strange way. I told you it was stupid. But, anyways I'll try to explain what I meant by that. I think reading the above paragraph you might have got some idea about what I was speaking. If not, then my english is too bad and I am bad at explaining something. Vibrations, I mean to say as variations. Isn't field a variation? If it isn't the variation of something- in almost every case its the displacement of particle and anti-particle pair that transmits the fields (Quantum field theory)- then the field doesn't spread. [Correct me if I am wrong] I assumed these to be like vibrations- displacement from their mean positions. Heat is always a big question to me similar to the one I mentioned- about the virtue of positions. Electromagnetic interaction, well, that's the point of the principal question I posed here and hoped to find some answers, or atleast some suggestions. Let me know If I assumed something wrong or interpreted the concept wrongly into me. |
| Apr19-12, 10:06 PM | #6 |
| Apr20-12, 06:10 AM | #7 |
| Apr20-12, 10:55 AM | #8 |
One thing is for sure I get from this. My English is too Bad to continue in here. First, I'll try to learn as much English as I can and then return back to this forum to post something. Until then, I think I have to keep quiet not answering or speaking about something. Anyway thank you very much. Finally, a correction of your statement. Perhaps, it was a typing or grammatical mistake. Anti-matter is something opposite to matter. Right? So does it have mass! I may agree with the concept of it having volume, but not mass. I may be wrong, but check it out. It seems so logical, infact a little paradoxical to me. I think its beyond my scope too, to understand this concept for now. This was what I was asking about. The precise word "interact". The process and phenomena underlying it. Anyway, thank you very much :) |
| Apr20-12, 02:19 PM | #9 |
| Apr20-12, 08:13 PM | #10 |
Mentor
Let me remind everyone to reread the PF Rules on Overly Speculative Posts.
| New Reply |
| Tags |
| charge, energy, mass, matter, relation |
Similar discussions for: What's the precise relationship between Mass and Charge
| Relationship of particle charge to speed? | Introductory Physics Homework | 3 | ||
| relationship between electron and quark charge | Quantum Physics | 7 | ||
| capacitors charge and voltage relationship | Introductory Physics Homework | 10 | ||
| Relationship between mass of cart, mass on a pulley and resulting acceleration | Introductory Physics Homework | 3 | ||
| Relationship between volts and charge | Introductory Physics Homework | 4 | ||
