Questions About Vaccuum/Air Force And Its Usage
  • Thread starter Thread starter Blowgunner
    Force
The discussion revolves around a proposed airgun design that utilizes vacuum and air pressure instead of a spring mechanism to propel a projectile. Participants explore the feasibility, materials, design considerations, and performance metrics of this model, along with comparisons to conventional airguns.
  • One participant questions the practicality of the proposed model and requests more details for better understanding.
  • Another participant draws parallels to hydraulic intensifiers, suggesting that while the proposed design may resemble such systems, it fundamentally differs as it operates on vacuum rather than hydraulic pressure.
  • A participant emphasizes the role of air pressure in the operation of the proposed airgun, likening it to the behavior of a syringe when the piston is pulled back.
  • There is a suggestion that the problem can be approached using the formula F=P*A, indicating a relationship between force, pressure, and area.
  • One participant seeks clarification on the term "delta P" and expresses a desire to understand the relationship between the dimensions of the vacuum tube and the force generated.
  • Questions are raised about measuring the force of air expelled from the device and the expected efficiency of the proposed model.
Participants express differing views on the feasibility and mechanics of the proposed airgun design. There is no consensus on the practicality of the model or the specifics of its operation, with multiple competing perspectives on how vacuum and air pressure interact in this context.
Participants note that many questions remain unanswered due to a lack of specific details about the design and operational parameters of the proposed airgun. The discussion includes assumptions about pressure differentials and the relationship between tube dimensions and force generation.
Blowgunner
Hello experts
I have quite a number of questions about a project that is basically an airgun, but uses the force of air/vaccuum instead of a spring to blow the air. Here is a brief description of the whole model:
There are two tubes, one placed in the other, such that there is some space between them.
There are two pistons too. The first piston operates between the space between the two tubes, and the other operates in the inner tube. Note that the inner ends of the pistons fit precisely in their vicinity such that air cannot move past either of them.
These two pistons are connected together outside the tubes for convenience so that there is only one piston handle outside the tubes.
The outer tube has an opening at one end (the end opposite to the piston handle) while the inner tube is tightly closed on one side such that when the piston is pulled back, vacuum is created in the inner tube.
Now we have formed a machine which blows air with the force of vacuum. When the piston is pulled backwards, the space between the two tubes will be filled with air, while the inner tube will have vacuum in it. When the piston is released, the pressure of air will push the piston inside the inner tube (because there's vacuum in it). But since the two pistons are connected, the piston of the space between the tubes is also pushed forward, hence blowing air out of the opening.
Now I put my questions:
1- Is this model practically attainable?
2- Which material should be used for the inside and outside tubes?
3- What are the advantages/disadvantages of this model against the conventional airguns which use the force of a spring to blow air outside a tube?
4- What should be the diameter of the inner and outer tubes if we want to blow a dart of mass 50g to a distance of 200m through this device?
5- Is there a company/firm where I can order this model?
6- And lastly, does anyone have an estimate of the cost of a prototype?
I would imagine that the reason nobody has replied yet is that some of your questions cannot be answered without knowing many more details. You also don’t give my mind enough information to completely understand what you are doing. I don’t know if that problem lies mostly in my mind or in your presentation.
But you might know that there is an alternant design that is common use in the hydraulics and pneumatics industry. I used these “hydraulic intensifiers” in a previous job when my power supply put out 3000 psi, but I needed to generate a small amount of fluid at 20,000 psi. They take a small pressure to drive a larger pressure. They do not work on a vacuum. But an alternant design would make them work with a vacuum. Perhaps that is what you are presenting here, but I just don’t see it.
Suppose you have a regular double acting hydraulic cylinder. The area of the piston is 10 and the rod has an area of 9. (Substitute any units you like.) This means that on one side of the piston, the annular area has an area of 1. So if the rod is free and not connected to anything, and I put a pressure of 100 on the large area side of the piston, then the piston area on the rod side of the piston will generate a pressure of 1000.
An alternant means of building an intensifier is to couple the shafts of two fixed displacement pumps together. If you supply fluid to the one with the larger displacement, then the smaller displacement pump will produce a pressure that is higher by the ratio of displacements.
The question is not about the pressure caused by a hydraulic cylinder. Its about the force of the vacuum (or rather the air in fact). When you fill the needle of a syringe with dust and then pull the piston back it rushes to its original position when you release it. Due to the pressure of air around the syringe.
The question is about using this force as a spring i.e. how much wide a tube (with vacuum inside it) would cause enough force to push the piston of another tube which is filled with air.
Sounds like a simple F=P*A problem.
You might bound your solution by assuming you can achieve a delta P of perhaps .4 - .7 bar.
What is a "delta P"?
Its not about solving some numerical problem. I'm trying to figure out a means to convert a blowgun into an airgun without using springs.
What I really want to know is this:
What is the relation of the area of the vacuum tube with its length? i.e. will a long but narrow tube create more force than a short but wide tube?
How do we measure the force of air (which is pushed out through the air-filled tube) w.r.t. the speed at which it is blown out?
How much efficiency should I expect from this model?
  • · Replies 45 ·
10K
  • · Replies 27 ·
  • · Replies 23 ·
