How Does Moving an Electron Affect Proton-Electron System Energy?
Moving an electron from a distance r from a proton to infinity results in a change in the system's energy, which is defined as zero at infinity. This process requires energy input, which is converted into potential energy stored in the electric fields surrounding the charges. The law of conservation of energy remains intact, as the energy is not lost but rather redistributed within the electric fields. The energy associated with the electric fields increases as the electron is moved away.
  • Understanding of electric fields and potential energy
  • Familiarity with basic concepts of atomic structure
  • Knowledge of conservation of energy principles
  • Ability to perform integration in physics contexts
  • Study the concept of electric field energy density
  • Learn about potential energy calculations in electrostatics
  • Explore the principles of conservation of energy in electric systems
  • Investigate the mathematical integration of energy in electric fields
Students of physics, educators teaching electrostatics, and anyone interested in the principles of energy conservation in atomic systems.
sharma_satdev
Suppose an electron initially present at distance r from the proton is moved away to infinity,the energy of the system is taken to be zero.If it is so where does the energy pumped into shift away the electron goes and thus the law of conservation of energy is violated
You need energy to do this.
Ok, this is an arbitrary definition of the energy. Fine.
It is now potential energy. You can even calculate it, if you integrate over the energy stored in the electric fields around the charges and compare this to the field configuration with the electron at distance r.
No. You increase the energy of the electric fields.
  • · Replies 21 ·
  • · Replies 28 ·
