Water held in straw by vacuum. Is this possible on grand scale?
  • Context: High School
  • Thread starter Thread starter martiwood
    Scale Vacuum Water
The discussion revolves around the feasibility of holding water in a large pipe or tube using vacuum and air pressure, inspired by the common trick of using a straw. Participants explore the potential for creating a large water feature in a home, questioning the mechanics involved in maintaining water in a vertical structure without it spilling out.
  • One participant describes successfully using a 2-inch pipe and a water pump to replicate the straw effect, questioning if this could be scaled up for a larger installation.
  • Another participant challenges the feasibility of holding water in a vertical 5 cm pipe, arguing that air would replace the water, causing a loss of vacuum.
  • A participant proposes that if a vacuum is maintained above the water, atmospheric pressure could theoretically hold the water up to a height of approximately 10.3 meters, based on calculations involving pressure and force.
  • Some participants suggest experimenting with different tube diameters and fluids to determine the limits of this phenomenon.
  • There is a discussion about the role of surface tension in maintaining water in larger diameters, with one participant questioning if any fluid could achieve this in a 10-foot diameter pipe.
  • Another participant points out the difference between a straw and a cup, emphasizing that both sides must be closed for the water to stay in the straw.
  • Concerns are raised about the practicality of maintaining a vacuum in larger structures compared to smaller tubes.
Participants express differing views on the feasibility of holding water in larger pipes, with no consensus reached on whether it is possible or what conditions would be necessary for success.
Some calculations and assumptions about pressure and fluid dynamics are presented, but there are unresolved questions about the effects of tube diameter, fluid type, and the maintenance of vacuum in larger structures.
martiwood
We all know the trick of holding water in a drinking straw by holding your thumb over the top creating a vacuum I know its also to do with air pressure below. I managed this on a bigger scale using a 2inch pipe, a water pump and a valve i could close at the top of the pipe to replicate the thumb. Now I am wondering if this could be achieved on a grand scale ? I would love to create a water feature in my home a 6 or 10 foot wide pipe cut short in the ceiling filled with water that people could walk under, touch or even take a glass of water from! Is this possiblle before i turn my house into one giant puddle ?
Take a glass of water put your hand on it ,turn it and release your hand. I think think this answers your ceiling pool question.
and i seriously question if you had a vertical 5 cm pipe holding water with the no bottom on the pipe.
it works for a straw that is thin enough because of the surface tension of the fluid. but a 5 cm pipe will have water trickling down one side with air replacing it on the other side. then that air will bubble up to the top and your vacuum is degraded.
so frankly, i don't believe it.
If inside the "straw" or whatever you had a vacuum above the water then I guess you could say the weight of the water will pull it down and the force from atmospheric pressure will try to keep it up.
mass of the water would be volume*density: ∏r2*H*1000
so the weight will be ∏r2*H*1000*9.8
Pressure*area = force
force= 101325*∏r2
so we have 101325*∏r2 = ∏r2*H*1000*9.8
101325 = 9800H
H ≈10.3m (calculations were done using SI units)
So I guess you can hold up to 10.3m of water before it falls, independent of how wide the pipe is.
Who knows though, maybe I'm missing something important when I thought of this.
A cup won't have both sides open so I'm not sure what you mean?
And I'm not sure what you mean! A straw doesn't have "both sides open" either- if you have the sides open, the water will not stay- and that's the whole point here.
martiwood,
That sounds like the perfect opportunity for a scientific experiment. A straw is a just a tube. You could try getting a series of tubes with different diameters, then seeing at what diameter you could no longer hold the water with air pressure.
Of course you might want to think about what other variables might have an effect... maybe the tube length too? Or you could try the experiment with different fluids, maybe honey or vegetable oil something :D
(I am not suggesting you make a mess of the house ;) )
One might also ask "what would the surface tension of a fluid have to be to pull this trick off in a 10 foot diameter" and then see if any such fluids exist.
This 10 foot water feature would work in zero to very low G.
force= 101325*∏r2
101325 = 9800H
is the bottom of the pipe stuck into a pail of water, like a water barometer? that will work, independent of the diameter of the pipe.
but i can poke a 1/4-inch diameter straw into water (or soda or juice), put my thumb over the top, pull the straw out (holding it vertically, the same as it was poked into the liquid) and the water does not fall to the table until i lift my thumb offa the top of the straw. (this is different from how a tube of fluid is made into a barometer because the bottom is still inside the pool of fluid.)
and what i am saying is that you can't do that with a 2-inch diameter pipe unless the liquid is molasses or something like that.
  • · Replies 43 ·
14K
  • · Replies 30 ·
10K
  • · Replies 42 ·
25K
9K
