Rieman Integral: The Fundamental Theorem of Calculus
The discussion revolves around the application of the Fundamental Theorem of Calculus and the Leibniz integral rule in the context of differentiating an integral defined by a function that is itself dependent on another variable. The problem involves continuous and differentiable functions and their relationships through integration and differentiation.
  • Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants explore the appropriate theorems to apply, particularly the Leibniz integral rule and its connection to the chain rule. There is uncertainty about how to differentiate the integral and the role of the function f within that context.
Some participants have suggested using the Leibniz integral rule to approach the problem, while others are questioning the interpretation of the derivative of G(x) and its relationship to the function f in the integral. The discussion is ongoing with various interpretations being explored.
There is a mention of the need for clarity regarding the definitions and roles of the functions involved, particularly concerning the upper limit of integration and the application of differentiation rules.
kingstrick
Let I := [a,b] and let f: I→ℝ be continuous on I. Also let J := [c,d] and let u: J→ℝ be differentiable on J and satisfy u(J) contained in I. Show that if G: J→ℝ is defined by
G(x) :=∫u(x)af for x in J, then G'(x) = (f o u)(x)u'(x) for all x in J.
2. The attempt at a solution
I am not sure what theorem to use in this situation. I am thinking that the product and composition of differentiable functions means that G'(x) exists...but I don't believe that will help me in this situation. Any ideas as to how i should start this one?
The Leibniz formula that Dick links to is basically using the chain rule.
If [itex]F(x)=\int_a^{g(x)} f(t)dt[/itex] let u= g(x) so that the integral is
[itex]\int_a^u f(t)dt[/itex] and, by the Fundamental theorem of Calculus,
[tex]\frac{d}{du}\int_a^u f(t)dt= f(u)[/tex]
Now, use the chain rule to find the derivative with respect to x.
I don't understand. Isn't the derivative of G(x) the f in the integral. Or am i supposed to find the derivative of F(X)?
No, the derivative of G(x) is NOT "the f in the integral". If the upper limit were just "x" it would be.
  • · Replies 39 ·
  • · Replies 105 ·
13K
