Finding volume between two surfaces.
  • Thread starter Thread starter bigbk92
    Surfaces Volume
This discussion focuses on calculating the volume between two surfaces defined by the equations z = x^2 + 3y^2 and z = 8 - x^2 - y^2. The correct approach involves setting the two equations equal to find the limits for y, which results in y = ±(1/2)√(4 - x^2). The volume is determined by integrating the difference between the upper surface and the lower surface, specifically (8 - 2x^2 - 4y^2). The final volume calculation yields 18π after proper integration over the specified limits.
  • Understanding of double integrals in calculus
  • Familiarity with surface equations and their intersections
  • Knowledge of polar coordinates and Jacobians
  • Proficiency in using integration techniques for volume calculations
  • Study the method of setting up double integrals for volume calculations
  • Learn about polar coordinates and their application in volume integrals
  • Explore the concept of Jacobians in changing variables during integration
  • Practice problems involving the volume between surfaces for deeper understanding
Students and professionals in mathematics, particularly those studying calculus and multivariable functions, as well as engineers and physicists involved in volume calculations between surfaces.
bigbk92
I am having trouble finding the volume between the two surfaces. Well I did the problem and got an answer but I am not sure if I am approaching this type of problem correctly. So can you take a look at how i approached the problem and tell me if i am on the right path or if it is incorrect. Thank you in advance.
Find the volume between the two surfaces
z = x^2 + 3y^2
z = 8 - x^2 - y^2
First I set both equations equal to each other to get y =±sqrt(2 - x^2).
Finding the volume will require a double integral so this can be my y limits.
X cannot exceed sqrt(2) so i assume my x limits are ±sqrt(2)
The sum of the two functions is 2y^2 + 8. I believe this is what i should integrate. If not please tell me what i should integrate and why.
So i integrate 2y^2 + 8 with respect to y and get (2/3)y^3 + 8y. And inputting the y limits yields (4/3)*(2 - x^2)^(3/2) + 16*(2 - x^2)^(1/2).
Now i integrate that with respect to x using the computer and get
18*arcsin(sqrt(2)x/2) - (1/3)x*(x^2 - 5)*sqrt(2 - x^2) + 8x*sqrt(2 - x^2)
Putting in limits of ±sqrt(2) gets a final answer of 18*pi.
z = x^2 + 3y^2
z = 8 - x^2 - y^2
Well, you shouldn't get that! Did you forget the "3" multiplying [itex]y^2[/itex] in the first equation? [itex]z= x^2+ 3y^2= 8- x^2- y^2[/itex] gives [itex]2x^2+ 4y^2= 8[/itex]
or [itex]x^2+ 2y^2= 4[/itex]. That's an ellipse. Solving for y, [itex]y= \pm(1/2)\sqrt{4- x^2}[/itex].
If the "ceiling" is given by f(x,y) and the "floor" by g(x,y) the "height" is f- g, not f+ g. Subtract, don't add! Here, the "ceiling" is [itex]f(x,y)= 8- x^2- y^2[/itex] and the "floor" is [itex]g(x,y)= x^2+ 3y^2[/itex]. The distance between them, the height, is [itex](8- x^2- y^2)- (x^2+ 3y^2)= 8- 2x^2- 4y^2[/itex].
So I integrate 2y^2 + 8 with respect to y and get (2/3)y^3 + 8y. And inputting the y limits yields (4/3)*(2 - x^2)^(3/2) + 16*(2 - x^2)^(1/2).
As above, x goes from -2 to 2 and, for each x, y goes from [itex]-(1/2)\sqrt{4- x^2}[/itex] to [itex](1/2)\sqrt{4- x^2}[/itex].
[tex]\int_{x=-2}^2\int_{-(1/2)\sqrt{4- x^2}}^{(1/2)\sqrt{4- x^2}}8- 2x^2- 4y^2 dydx[/tex]
Another way to do this is to write the ellipse, at which the two paraboloids intersect, as
[tex]\frac{x^2}{4}+ \frac{y^2}{2}= 1[/tex]
Let [itex]x= 2rcos(\theta)[/itex], [itex]y= \sqrt{2}rsin(\theta)[/itex] so that the Jacobian is
[tex]\left|\begin{array}{cc}\frac{\partial x}{\partial r} & \frac{\partial x}{\partial \theta} \\ \frac{\partial y}{\partial r} & \frac{\partial y}{\partial\theta}\end{array}\right|= \left|\begin{array}{cc}2cos(t) & -2rsin(\theta) \\ \sqrt{2}sin(\theta) & \sqrt{2}rcos(\theta) \end{array}\right|= 2\sqrt{2}r[/tex]
And the integrand is [itex]8- 2x^2- 4y^2= 8- 4r^2cos^2(\theta)- 8r^2sin^2(\theta)[/itex]. You can use the fact that [itex]sin^2(\theta)+ cos^2(\theta)[/itex] to write this as [itex]8- 4r^2(cos^2(\theta)+ sin^2(\theta))- 4r^2sin^2(\theta)= 4- 4r^2sin^2(\theta)[/itex]
so the integral would be
[tex]\int_{r=0}^1\int_{\theta= 0}^{2\pi} (4- 4r^2sin^2(\theta))(2\sqrt{2} r dr d\theta)[/tex]
