Coulomb Energy Unit Conversion: MeV
The discussion revolves around the conversion of Coulomb energy between nuclei into MeV, specifically using the formula ΔE = (3e²/5r)(2Z-1), where r is in fermis, e is the elementary charge, and Z is a dimensionless quantity. The original poster is attempting to reconcile this energy calculation with rest mass values, which are expressed in MeV.
  • Exploratory, Assumption checking
  • The original poster questions how to convert the calculated Coulomb energy into MeV and expresses confusion regarding unit conversions. Some participants reference the relationship between eV and joules to aid in the conversion process.
Participants are exploring the conversion of units and discussing the implications of using different measurement systems. A reference to a coefficient for conversion has been mentioned, but there is a sense of dissatisfaction regarding the depth of explanation provided.
The original poster is comparing Coulomb energy with rest mass, which is given in MeV, indicating a need for consistent units in their calculations. There is an acknowledgment that eV is not an SI unit, which adds to the complexity of the discussion.
atomicpedals
I'm having some difficulty resolving the units (unit conversions will be my great un-doing) for calculation of the Coulomb energy between nuclei. Given that
[tex]\Delta E = \frac{3e^{2}}{5r} (2Z-1)[/tex]
with the value for r in fermis (~10^-13cm), the elementary charge e in coulombs, and Z is dimensionless. How can I resolve this into MeV? Or can I?
The problem which brought this on is to compare the difference in rest mass with the Coulomb energy. With the rest mass being in MeV it would seem that I would need the Coulomb energy in similar units, but I'm just not seeing how to do it.
I've found a reference to the coefficient with e and r being 0.807MeV. While that's useful for completing the problem-set it leaves me a bit unsatisfied as far as explanations go.
hi atomicpedals! :smile:
atomicpedals said:
… with the value for r in fermis (~10^-13cm), the elementary charge e in coulombs, and Z is dimensionless. How can I resolve this into MeV?
so you'll have to use eV = 1.602 10-19 J :wink:
...*face-palm*
Yep... and that does it. Thanks!
  • · Replies 0 ·
12K
10K
