Sketching $$f(x)=4-x^2$$ and Proving its Concavity in D=[-2,2]
  • Thread starter Thread starter Dostre
The discussion revolves around the function $$f(x)=4-x^2$$ defined on the interval D=[-2,2]. Participants are tasked with sketching the function and proving its concavity using the definition of a concave function without resorting to derivatives.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss the properties of the function, noting it is a down-facing parabola. They explore the definition of concavity and the necessary inequality conditions. Questions arise about the requirements for the parameters involved, particularly the range of $$\lambda$$.
There is an ongoing exploration of the inequality that defines concavity. Some participants have made attempts to manipulate the inequality but express uncertainty about the next steps. Others have identified potential errors in assumptions regarding the values of u and v, leading to further clarification of their characteristics.
Participants are working under the constraint of not using derivatives and are required to prove concavity through algebraic manipulation of inequalities. The discussion reflects a mix of correct and incorrect assumptions about the values of u and v, which are relevant to the proof being attempted.
Dostre
Let D=[-2,2] and $$f:D\rightarrow R$$ be $$f(x)=4-x^2$$ Sketch this function.Using the definition of a concave function prove that it is concave (do not use derivative).
Attempt:
$$f(x)=4-x^2$$ is a down-facing parabola with origin at (0,4). I know that.
Then, how do I prove that f(x) is concave using the definition of a concave function? I got the inequality which should hold for f(x) to be concave:
For two distinct non-negative values of x u and v
$$f(u)=4-u^2$$ and $$f(v)=4-v^2$$
Condition for a concave function:
$$ \lambda(4-u^2)+(1-\lambda)(4-v^2)\leq4-[(\lambda u+(1-\lambda)v]^2$$
After expanding the inequality above I get:
$$(\lambda u-\lambda v)^2\leq(\sqrt{\lambda} u-\sqrt{\lambda} v)^2$$
I do not know what to do next.
Attempt:
You have to show that the above is true, not assume it's true.
Isn't it also required that 0 ≤ λ ≤ 1 ?
Yeah it is required that 0 ≤ λ ≤ 1.
But, how do I prove that the below inequality is true?:
$$λ(4−u)^2+(1−λ)(4−v)^2≤4−[(λu+(1−λ)v]^2$$
Without Loss of Generality, let u ≥ v .
What else do you know about u & v ?
That they are non-negative. I was working on this problem for a long time and I managed to turn the inequality:
into
$$\lambda (u-v)^2(1-\lambda)\leq0$$
Since 0<λ<1 the above inequality is true and the function f(x) is concave. I think it is correct.
into
Why do you say u & v are non-negative?
Oh no they are not. My mistake. I was looking at another problem I am doing right now. It does not really matter whether they are negative or not for this inequality since the power of 2 makes their difference positive. But yeah they can be negative since they are distinct values of x and the the domain of x is [-2,2].
  • · Replies 105 ·
13K
  • · Replies 20 ·
