New Reply
Thermodynamics: Vapor Compression Refrigeration that is Adiabatic?
Share Thread
Apr23-12, 11:36 AM   #1
Consider a heat pump works on the vapor-compression refrigeration cycle with 0.2 kg/s of refrigerant-134a as the working fluid. The cycle is used to maintain a house at 26oC while absorbing heat from the outdoors at 3oC. R-134a enters the compressor at 200 kPa as a saturated vapor and leaves at 900 kPa, 50oC. The refrigerant leaves the condenser as a saturated liquid. Assuming the four devices to be well-insulated:
I need to find COP, but in order for that i need QH, which i cant have because all the devices are insulated. How do i proceed?
PhysOrg.com science news on PhysOrg.com
>> City-life changes blackbird personalities, study shows
>> Origins of 'The Hoff' crab revealed (w/ Video)
>> Older males make better fathers: Mature male beetles work harder, care less about female infidelity
Apr26-12, 02:51 AM   #2
COP (heating)=Q-hot/W-net,in
COP (heating)=M-dot * (h2-h4)/m-dot * (h2-h1)
Pt 1: 200 kPa,3 C
Pt 2: 900 KPa,50 C
Pt 4: 900 KPa, 26 C
See if that works
Apr26-12, 04:26 AM   #3
Correction
Pt 1:200 kPa, sat. Vapor, -9 C
Pt 2: 900 kPa, 50 C
Pt 4: 900 kPa, sat. liquid, 35.4 C
Find enthalpy' s for various points, use equation for COP-heat
Apr27-12, 02:40 PM   #4
Thank you
New Reply
Similar discussions for: Thermodynamics: Vapor Compression Refrigeration that is Adiabatic?
Thread Forum Replies
Thermodynamics: Vapor-compression refrigeration Engineering, Comp Sci, & Technology Homework 0
Help needed understanding the Vapour-Compression Cycle in refrigeration General Engineering 2
COP in vapor compression refrigeration analysis Classical Physics 5
Vapor Comression Refrigeration cycle General Engineering 17
Thermodynamics: Adiabatic Compression Introductory Physics Homework 2
