Contour integration: why is this integral non-zero
  • Context: Graduate
  • Thread starter Thread starter geoduck
    Integral Integration
The discussion revolves around the evaluation of the integral \int_{1}^{\infty} dx \sqrt{x-1} \mbox{ }e^{-x^4} using contour integration techniques. Participants explore the conditions under which the integral may or may not vanish, considering the behavior of the integrand and the chosen contour.
  • Exploratory, Technical explanation, Debate/contested, Mathematical reasoning
  • Some participants question why the integral does not vanish, given that the integrand has no poles and the contributions along the real axis appear equal.
  • Others argue that the contour integral around the large circle should yield a zero value due to the exponential decay of the integrand.
  • A participant points out that the square root function is double-branched, which complicates the evaluation around the contour.
  • There are claims that the integral over the large circle is not zero, and that the function remains positive over the interval [1, ∞).
  • Some participants suggest that there are mistakes in the equations presented, proposing alternative formulations that lead to different conclusions about the contour integral.
  • A later reply highlights that the chosen contour may not be suitable for computing the integral accurately.
  • One participant notes that the integral does not vanish along certain paths, indicating that the behavior of the integrand is more complex than initially assumed.
Participants express differing views on the evaluation of the integral and the behavior of the contour. There is no consensus on whether the integral can be considered zero or not, and multiple competing interpretations of the contour integration approach remain.
Limitations include the dependence on the choice of contour and the assumptions about the behavior of the integrand at infinity and around branch points. The discussion reveals unresolved mathematical steps and differing interpretations of the contour's impact on the integral.
geoduck
Just out of curiosity, why doesn't
[tex]\int_{1}^{\infty} dx \sqrt{x-1} \mbox{ }e^{-x^4}[/tex]
vanish by contour integration?
The contour starts just above the real x-axis at x=1, goes rightward to x=infinity, then counter-clockwise from 0 to 2pi, then it goes leftward back to x=1.
Since the integrand has no poles, the entire integral should be zero. Along the real axis, the leftward and rightward contributions are equal. At infinity the contributions are zero. So it seems that the entire integral should be zero.
This is absurd of course, but I can't figure out where I went wrong in my logic.
*** Excuse me: where exactly does the contour "turns counterclockwise from 0 to 2pi" ?!
DonAntonio
geoduck said:
Since the integrand has no poles, the entire integral should be zero..
No. I get:
[tex]\int_1^{\infty} f+\int_R f+\int_{\infty}^1 (-f)+\int_{\rho}=0[/tex]
It's zero around the small indentation around the origin. so:
[tex]2\int_{1}^{\infty} f dz=-\int_{R} f dz[/tex]
And since the integral is a positive real number, the limit of the integral over the large circle must be the negative of twice that number.
jackmell said:
No. I get:
What "large circle" and what "little indentation around the origin"? I can't see any in the OP's original post...
In fact, the integral is defined only for [itex]x\geq 1[/itex] , not even close to the origin.
DonAntonio
I've attached a picture of the contour that I'm talking about.
Apologies for not being clear.
Shouldn't the integral along the contour of the large circle give a zero value, since the exponential term makes the integrand zero around the large circle?
Oh, I see now! Well, you know the square root is a double-branched function, and when you go around on that circle, its value
jumps, so it is not that "obvious" what goes on there.
Of course, there's a simple reason why your integral can't be zero: the function in the integral is non zero in
a whole non-trivial interval in [itex][1,\infty)[/itex], since the function is always positive in [itex](1,\infty)[/itex] ...
DonAntonio
I think that there is a mistake in the next equation :
[tex]\int_1^{\infty} f+\int_R f+\int_{\infty}^1 (-f)+\int_{\rho} f = 0[/tex]
It should be :
[tex]\int_1^{\infty} f+\int_R f+\int_{\infty}^1 f+\int_{\rho} f = 0[/tex]
or
[tex]\int_1^{\infty} f+\int_R f-\int_1^{\infty} f+\int_{\rho} f = 0[/tex]
[tex]\int_R f-\int_{\rho} f = 0[/tex]
So, the contour integration leads to zero and it is not in contradiction with [tex]\int_1^{\infty} f > 0[/tex]
In fact, the chosen contour is not convenient to compute the integral.
It should be :
or
I don't think so Jacquelin. It's negative along the contour beneath the real axis and goes from infinity to 1 so it's correct as I've written it and although we cannot check that numerically because of the large exponent, we can check the formula with an equivalent one with smaller exponent:
[tex]\int_{c} \sqrt{z-1} e^{-z}dz[/tex]
which agrees with the formula I stated.
Also, sorry in my confusion of my first post. The small contour was going around the point 1 and not zero.
Thanks everyone. It turns out, as some have noted, that the integral over the large circle is not zero.
I chose the argument to be -z^4 because I thought no matter if you insert +i∞ or -i∞, it'll become -∞^4, which makes the exponential vanish. But there are other directions between those two directions where the integral does not vanish (and even blows up).
  • · Replies 20 ·
  • · Replies 16 ·
