New Reply
Torque on a shaft connecting to a wheel
Share Thread Thread Tools
Apr25-12, 07:23 AM   #1
zuq
hi guys
Lets say I have a wheel that is driven by a shaft connected straight to a motor.
Wheel raidus is 0.0762m while shaft raidus is 8mm.
If I know the torque acting on the wheel, say 20Nm , what would be the torque on the shaft?
Thanks
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Galaxies fed by funnels of fuel
>> The better to see you with: Scientists build record-setting metamaterial flat lens
>> Google eyes emerging markets networks
Apr25-12, 10:22 AM   #2
Exactly the same.
Apr25-12, 10:33 AM   #3
It's an abiguously worded question.
Is the 20Nm applied by the motor? Or applied at the wheel (as a brake), or is it a net torque?
A torque acts about an axis.
If the axis of the wheel and the shaft axis are colinear, they are the same.
Apr25-12, 10:39 AM   #4
zuq
Thanks Pkurse and xxChrisxx
@xxChrisxx
My background is in electrical, so bare with me please.
This is for a kart where say 50Newtons of drag force is opposing the karts movement. In terms of torque at wheels, for a radius of 0.5m say it becomes 25Nm.
Now if the motor is directly coupled to the wheel, with shaft radius of say 0.25m (overly exaggerating) will the torque produced by motor be 25Nm in steady state conditions?..i.e. not accelerating and keeping at a constant velocity.
And offcourse the motor and wheel will have same RPM.
Apr25-12, 12:37 PM   #5
If motor shaft is directly coupled to the wheel, then they see the same torque. Assuming one wheel drive, r at .25, drag at 50, then torque is 12.5.
New Reply
Tags
force, torque, wheel
Thread Tools
Similar Threads for: Torque on a shaft connecting to a wheel
Thread Forum Replies
Connecting motor shaft to thrust bearing Mechanical Engineering 6
Pulleys connecting a motor and shaft - Determining loads in shafts Engineering, Comp Sci, & Technology Homework 1
Angular velocity of a connecting rod on a rotating wheel. Calculus & Beyond Homework 4
calculate wheel torque based on known Weight, wheel size, acceleration data ? General Physics 9
shaft that rotates a wheel Introductory Physics Homework 1
