Dropping two magnets through a copper tube
  • Context: Undergrad
  • Thread starter Thread starter Xiao10
    Copper Magnets Tube
The discussion centers on the behavior of two bar magnets dropped through a copper tube, specifically when the same poles face each other, causing repulsion. Participants hypothesize that the magnets will fall slightly faster than a single magnet due to decreased magnetic field density between them, resulting in reduced eddy current strength. An initial experiment suggested minimal observable effects, but the setup was deemed unreliable. The consensus indicates that the lower magnet may fall quicker while the upper magnet experiences a slower descent due to their mutual repulsion.
  • Understanding of magnetic fields and poles
  • Knowledge of eddy currents and their effects
  • Familiarity with experimental physics and setup reliability
  • Basic principles of magnetism and motion through conductive materials
  • Conduct a controlled experiment to measure the fall rates of magnets in a copper tube
  • Research the principles of eddy currents in conductive materials
  • Explore the effects of magnetic field interactions on motion
  • Learn about the design and reliability of experimental setups in physics
Physics students, educators conducting experiments on magnetism, and anyone interested in the dynamics of magnetic interactions in conductive environments.
Xiao10
Hi,
In class we were discussing the effects of a two bar magnets being dropped through a copper tube at around the same time, with the same pole facing towards each other, so that the two magnets repel - would the magnets fall through the tube faster or slower than if only one was dropped through?
At a guess I think the magnets will fall slightly faster, the field density between the two magnets should be decreased as the lines are pointing in opposite directions, this means that flux is cut at a lesser rate so the strength of the eddy currents should be decreased.
(The experiment was attempted once, and the effect was seen to be small, however it was quite a unreliable set-up).
I think the lower one would fall quicker, the upper one would fall slower, as both are repelling and therefore accelerating away from each other ;).
Considering eddy currents: I don't know the relative sizes of your setup parts. However, the field lines are mainly parallel to the direction of movement, right? In that case, I wouldn't expect a large effect from eddy currents.
Thanks, that makes sense, will try the experiment again if time and equipment allowsl
  • · Replies 59 ·
  • · Replies 20 ·
