| New Reply |
is the following statement true or false. prove? |
Share Thread | Thread Tools |
| Apr26-12, 01:00 AM | #1 |
let a,b,c be three integers is a divides c and b divides c, then either a divides b or b divides a. if a,b,c,d are real numbers with a<b and c<d, then ac<bd. 2. Relevant equations 3. The attempt at a solution So for part 1 Since a/c and b/c then, c=ak and c=bd for some integers k,d. hence, ak=bd so a/b=d/k where d/k =l for some integer l. so a/b=l... Therefore a/b. end of proof. for part 2) a<b and c<d (given). let a= -5 and b=-4 satisfying a<b and let c=-7 and d=-5 satisfying c<d so then ac = 35 and bd = 20 so 35<20 but this is false therefore ac<bd is false. end of proof. Can Someone please tell me if I have done this correctly? |
| Apr26-12, 01:19 AM | #2 |
How do you know d/k is an integer? Try a few values out for a, b, and c and see how the corresponding d and k correlate. You should see the answer to the problem pretty quickly!
The second counterexample looks good! |
| Apr26-12, 01:46 AM | #3 |
Ok so a/c and b/c (given) let c=3 and a=9 and b=12 so 9=3k for some positive integer k and 12=3s for some positive integer s but 12 does not divide 9 and 9 does not divide 12. therefore a/b or b/a is false. but obviously I can make this statement true ie if k=6 and s=12... Although I guess this in not a "for some" statement... but I really don't like doing proofs this way. |
| Apr26-12, 06:15 AM | #4 |
is the following statement true or false. prove?In your example, 9 and 12 don't both divide 3. You have the definition backwards, a and b will be multiplied by the interger terms. |
| New Reply |
| Thread Tools | |
Similar Threads for: is the following statement true or false. prove?
| True or false: If it's true, give an example. If it's false, prove it. | Calculus & Beyond Homework | 3 | ||
| true,false statement | Set Theory, Logic, Probability, Statistics | 5 | ||
| true or false/correct if statement is false help | Biology, Chemistry & Other Homework | 2 | ||
| I can't figure out if this statement is true or false, i said false | Calculus & Beyond Homework | 4 | ||
| whether this statement is true or false | Introductory Physics Homework | 6 | ||
