| New Reply |
Need help with a thought experiment about point of view,motion, and gravity. |
Share Thread | Thread Tools |
| Apr26-12, 10:23 AM | #1 |
Ive been thinking about orbits. We have plenty of points of reference(stars) that help us determine our orientation within the milky way ect. So we can effectively determine orbital paths, rotation, ect. So Ive been thinking about the earth and the moons orbital interaction independently of any other point of reference, including the sun. When I do this, it no longer becomes possible to say whether the earth is rotating, the moon is orbitting(in a path at a velocity) or a combination of both. Following this thought, I wondered about where the momentum is. You could assume that the moon is stationary and that the earth is rotating, right? This gives the earth rotational energy but takes the moons momentum or you can say the moon is completing an orbital path every 24+- with a great deal of momentum and we are only slightly rotating. So does this mean that momentum is only a point of view relative to mass? Using the laws of conservation of energy/momentum the earth moon system has the same energy when compared to a 3rd mass at some other fixed point from just an energy/momentum standpoint indepedently of what the earth and moon are doing internally as a system, as I stated earlier. Now when I put this all into motion in my head it breaks down and I dont see why. If the energy can be moved/transformed( between earth and moon) by changing your point of view, then what keeps the moon from crashing into the earth due to gravity or from being flung off into space by reaching escape velocity? I may be having trouble conveying exactly what Im thinking, so I will state it as plainly as possible now. When examining the earth and moon in a directional-less empty universe, what keeps the earth and moon at the same distance if I choose to change the energy distribution between the two by changing my point of view? I can change my point of view right? Help please.
| Apr26-12, 02:46 PM | #2 |
Because every viewpoint is equally workable. So if the moon orbits the earth in our viewpoint, no matter what other reference frame you are in, the same total movement will happen. Its like if a person in a car passes a person standing on the street. The person in the car in say that the person standing is moving, and the person standing will say that the person in the car is moving, but both will agree that they passed by each other.
| Apr26-12, 03:48 PM | #3 |
| Apr26-12, 04:18 PM | #4 |
Mentor
In addition, the laws of physics as you want to use them only apply to inertial reference frames. Therefore, you cannot sit on the moon and say "see! Earth is orbiting around me!". You can measure the acceleration of the earth and moon independent of the system (this is an approximation for velocities much smaller than the speed of light and fine within this context) and measure that the acceleration of the moon is larger (ignore the sun for a moment). Therefore, the moon orbits the earth and not vice versa.
Velocity, momentum, kinetic energy and so on are all frame-dependent. However, acceleration, time and relative distance are the same everywhere (this is wrong in special relativity, but that does not change the message here), therefore you get the same physics in all frames. That physics is the same everywhere is a very fundamental statement, and one of the main ideas which lead to the concept of special and general relativity. |
| Apr26-12, 05:03 PM | #5 |
| Apr26-12, 06:02 PM | #6 |
| Apr26-12, 06:44 PM | #7 |
What I think you are referring is known as Mach's principle and you might want to look into that.
On the other hand physically, there is no such point as you describe. You will always have a changing distance between your bodies therefore you could in principle determine their dynamics. |
| Apr26-12, 07:08 PM | #8 |
| Apr27-12, 08:50 AM | #9 |
Mentor
The moon probably formed by material ejected from the earth, so there was no capture process. But other moons in the solar system might be the result of such processes. In that case, the moon has to transfer a part of its kinetic energy to other objects to get captured, right. |
| Apr27-12, 08:36 PM | #10 |
| New Reply |
| Thread Tools | |
Similar Threads for: Need help with a thought experiment about point of view,motion, and gravity.
| Thought experiment with two point sources of light | Introductory Physics Homework | 13 | ||
| Thought experiment regarding artificial gravity (Newton's third law in space) | General Physics | 2 | ||
| The Double Slit Experiment from a Photon Point of View | Special & General Relativity | 7 | ||
| Gravity, from a different point of view | General Physics | 4 | ||
