New Reply
Gfortran/f90 (MinGW) namelist eof?
Share Thread
Apr28-12, 04:42 PM   #1
I've written a small f90 program to read and write a file using namelists in Windows, MinGW. I've never tried this before.
I entered the name list using notepad. The name input namelist file looks like:
&WW_ANML aname="John Doe", age=44
Whenever I try to read it I get an eof indication. Do I need some special eof marker at the end of line?
PhysOrg.com science news on PhysOrg.com
>> New language discovery reveals linguistic insights
>> US official: Solar plane to help ground energy use (Update)
>> Four microphones, computer algorithm enough to produce 3-D model of simple, convex room
Apr28-12, 05:33 PM   #2
Recognitions:
Homework Helper Homework Help
eof means end-of-file.
When you read the number 44, your program tries to read another digit, but finds the end of the file, which it indicates.
Try to put a new line at the end of the line.
That will explain to your program that there is no other digit coming, without triggering the end-of-file indicator.
Apr28-12, 06:27 PM   #3
Thanks for your response.
I tried a CR. I'm using Win7. It didn't work.
I just happened to realize that I had used a 8 character string in the program, but in reality used a much longer name than John Doe. I boosted the 8 to 25. That fixed it.
Well, my next namelist challenge will be to read 2-dim arrays. I think the numerical data comes in a column at a time from a namelist to get into a (n,2) array.
New Reply
Similar discussions for: Gfortran/f90 (MinGW) namelist eof?
Thread Forum Replies
cuda for gfortran ? Programming & Comp Sci 4
using a batch file to create NAMELIST input file for FORTRAN Programming & Comp Sci 0
Adding an icon in mingw? Programming & Comp Sci 5
MinGW/MSYS problem with search path Programming & Comp Sci 2
Unusual Compiler Error (using Dev-C++ Mingw) Programming & Comp Sci 3
