Irrationality of this number. Proof.
  • Thread starter Thread starter charmedbeauty
    Proof
The discussion revolves around proving the irrationality of a number derived from the equation 2x² - 3 = 0, where x is a real number. Participants are examining the implications of this equation and the nature of the solutions it yields.
  • Some participants question the validity of the original proof attempt, noting that it incorrectly concludes that x must be irrational based on the parity of numbers. Others suggest clarifying the original problem statement and the reasoning behind the steps taken in the proof.
The discussion is ongoing, with participants providing feedback on the reasoning presented. There is a recognition of misunderstandings regarding the definitions of rationality and the properties of even and odd numbers. Some participants are exploring the implications of the proof and suggesting alternative approaches to demonstrate the irrationality of the derived number.
There is confusion regarding the original problem statement, with participants noting that the initial interpretation may have been incorrect. The discussion also highlights the need for clarity in logical reasoning and definitions used in the proof.
charmedbeauty
Prove that if x is a real number then 2x2-3=0
Well I think this proof is OK but it seems very to the point, please tell me if there is any fallacy in my reasoning.
2x2-3=0
2x2=3
but 2x2 is even, while 3 is odd
Hence x must be irrational for all real x.
2x2-3=0
2x2=3
All you proved is that x in not an integer.
What is the problem as stated for you to solve?
There are many things wrong. :frown:
This statement is false. x=0 is a counterexample: it satisfies the hypothesis, but not the conclusion.
2x2-3=0
2x2=3
For this bit, I can't tell if there's any problem with your reasoning, because you don't say what you're reasoning is -- you just wrote two equations.
The notion of "even" and "odd" applies to integers, but it doesn't apply to real numbers. If you are using x to denote a real number, then 2x2 is also 'merely' a real number, and so it doesn't make sense to talk about it being even.
This is another false statement. x=0 is another counterexample. It is real, however it is not irrational. It also has nothing to do with the statement you said you were trying to prove.
I hate to say it, but I think what you need to do is to focus on trying to understand logic, grammar, and the meaning of what you read/write, and also on explicitly writing out what you are thinking and doing.Would you please state exactly the question you were asked? I'm guessing it's something similar to
If x is a real number satisfying the equation 2x2 - 3 = 0, then x is irrational.​
Once you've stated the question, it may be useful to do one or all of the following:
  • Explain why your statement in the opening post means the same thing or doesn't mean the same thing as the question you were asked.
  • Explain why my statement means the same thing or doesn't mean the same thing as the question you were asked.
  • Explain why my statement means the same thing or doesn't mean the same thing as your statement in the opening post.
Ok I miss read the question and I thought it was for x an integer...
is this better.
Suppose that
2x^2-3=0
adding 3 two both sides of the equation
2x^2=3
dividing both sides by 2
x^2=3/2
taking the square root of both sides
x=√(3/2)
Now suppose that x is not irrational, ie suppose
x=p/q for some integers p/q
so √(3/2)=p/q
so √3/√2 =p/q
but √3 and √2 are both irrational.
Contradiction therefore x must be irrational.
The ratio of two irrational numbers can be rational, for example the square root of eight divided by the square root of two.
Do you know how to prove that the square root of two is irrational? A similar argument can be used here
Yeah I think it should be along the lines...
Assume that √2 is not irrational ie
√2=a/b (by definition of rationality).
so 2=a^2/b^2
so..
2b^2=a^2
Now a^2 is divisible by 2 and clearly so is a.
so let a=2k
so 2b^2=(2k)^2
2b^2=4k^2
b^2=2k^2
so b^2 is also divisible by 2.
Contradiction Since any rational number is a quotient or relative primes.
Therefore √2 is rational.
You last statement should be "[itex]\sqrt{2}[/itex] is NOT rational"!
Now apply those same ideas to [itex]\sqrt{3/2}[/itex].
oops, Ok thanks Halls of Ivy!
  • · Replies 24 ·
