| New Reply |
What typical voltages are induced from a typical magnet (50-75 gauss) |
Share Thread | Thread Tools |
| Apr30-12, 02:56 AM | #1 |
Hi, I'd like to use a millivoltmeter to research voltages induced from a basic ceramic magnet brushing by a conductor. So, I need to buy a millivolt meter. What voltage ranges will be required, and what read-rate should the millivolt meter have (in order for it to register the voltage in a split second brush with the magnet)? Is 1 millivolt a reasonable value to expect?
Any sources (books or online) you know I should check out related to this question? Also, it would be nice if it would record these voltages (or at least leave it displayed so I could record them). Can you suggest any particular model millivolt meter? |
| PhysOrg.com |
physics news on PhysOrg.com >> Promising doped zirconia >> New X-ray method shows how frog embryos could help thwart disease >> Bringing life into focus |
| Apr30-12, 10:10 AM | #2 |
Mentor
What is a "typical magnet"? Field strength is not even a parameter of the electromagnet itself.
Which type of experiment do you plan to perform? Without these things, it is impossible to give any number. |
| Apr30-12, 02:00 PM | #3 |
If you just want to show that a moving magnet can produce an induced emf then you will need a sensitive milliammeter or micro-ammeter. I would suggest an analogue meter so that you can see movement of the pointer. A digital meter might be difficult to interpret.
If you have access to an oscilloscope that should also give some indication and you may be able to store the information. |
| Apr30-12, 08:17 PM | #4 |
Thanks for the reply truesearch... astute observation about the analog meter--probably right about that. And yes, I should probably be in the micro amp range to be sure to be sensitive enough. An oscillascope also would be great, but I do not have access to one, saving the data would also be ideal. Glad you were able to have a sense of what I was looking to find out. Thanks.
| Apr30-12, 08:59 PM | #5 |
Thanks mfb for the reply,... by a typical magnet, I mean a permanent, ceramic magnet in the 50-75 gauss range, not an electro-magnet. The experiment I have in mind is to brush the permanent magnet across an insulated conductor (steel or copper) with different orientations of the permanent magnet in relation to the conductor (north-south direction oriented with the conductor--parallel or perpendicular), and record the various results.
I should probably use faraday's law to estimate the voltage, but I get confused when I try to appy it to this situation. I guess the number of turns would be 1. so you'd just have E = d(BA)/dt. B would be the magnetic field strengh, but A is the area? If the wire is straight where the magnet passes by, What area? Isn't the area usually the area of the coil? I guess it should have something to do with the distance of the magnet from the conductor--possibly. I guess B would go from 0 --> 50 gauss (is that the right units to use)? So, again, any help you can be regarding what range the voltmeter should be in, or possibly I should be observing the amps? And an appropriate (and cheap) model to use would be greatly appreciated. |
| Apr30-12, 09:01 PM | #6 |
Let's try using Faraday's Law:
[tex] \oint E \space d \ell = V = -N \int n \cdot \frac{dB}{dt}dA [/tex] N=100 turn coil A=0.0005 meters2 dB=0.0075 Tesla dt=0.1 seconds V = 100 * 0.0005 * 0.0075 /0.1 = 3.75 millivolts This is a very short pulse. |
| New Reply |
| Tags |
| induced voltage |
| Thread Tools | |
Similar Threads for: What typical voltages are induced from a typical magnet (50-75 gauss)
| Is this a typical way of doing proofs? | Academic Guidance | 1 | ||
| What do you do on a typical weekend? | General Discussion | 33 | ||
| How many LED's are in a typical LED monitor? | Engineering Systems & Design | 9 | ||
| Not typical UFOs | General Discussion | 2 | ||
| Typical Dilemma | Academic Guidance | 18 | ||
