What is the True Nature of Mass and Its Origins?
  • Context: Graduate
  • Thread starter Thread starter CarlosLara
    Mass
The discussion centers around the nature of mass, its definitions, origins, and the relationship between mass and energy. Participants explore various interpretations of mass, including its role in resistance to acceleration, its connection to the Higgs field, and its implications in physics, particularly in the context of relativity and gravity.
  • Some participants argue that mass is a measure of how much matter is confined within an object, while others challenge this definition by questioning what "matter" or "stuff" means.
  • Several contributions suggest that mass can be understood as resistance to acceleration, with references to Newton's second law (m = F/a).
  • There is a recurring theme that mass may arise from interactions with the Higgs field, though this is noted as speculative.
  • Some participants propose that mass is equivalent to condensed energy, with discussions on how this relates to the curvature of space-time.
  • Discussions also touch on the distinction between rest mass and relativistic mass, with some participants asserting that light has no mass while others argue about its properties at different speeds.
  • One participant raises a question about whether mass depends on gravity, leading to clarification that mass is constant in Newtonian mechanics, while weight varies with gravity.
  • There are claims that mass may be influenced by speed, referencing a formula related to relativistic mass, but participants express uncertainty about its implications.
  • Some participants express confusion or disagreement regarding the relationship between mass, energy, and gravity, with one participant proposing a model involving charges that is challenged by others.
The discussion contains multiple competing views on the definition and nature of mass, with no consensus reached. Participants express differing opinions on whether mass is a property of matter, a form of energy, or something else entirely.
Participants note various limitations in definitions and assumptions about mass, including the ambiguity in the term "matter," the distinction between rest mass and relativistic mass, and the implications of mass in different gravitational contexts.
CarlosLara
Good afternoon. I am wondering what exactly is mass. Some say, quite inaccurately, that it is a measure of how much "stuff" an object has (what do they mean by "stuff"?). Others say that it's a quantity that means resistance to acceleration. What is mass and where does the mass of particles come from? I read that it arises from spontaneous symmetry breaking of the electroweak force through interaction with 2 Higgs fields. Could anyone explain this in a very straightforward way?
Thank you in advance.
Mass is the amount of matter that is confined within a shape.
i.e for a gas m = n*M
Hi CarlosLara! :smile:
Asking "what is …" is ambiguous.
It can mean either "How come … ?" or "So what … ?"
The "so what" of mass is that it is resistance to acceleration (m = F/a).
The "how come" of mass is unknown, but maybe it comes from the Higgs field …
compare it with charge: some particles do not interact with the electromagnetic field, and so we say they have zero charge: others do interact via a "coupling constant" which we call the charge …
similarly, loosely speaking, maybe the photon does not interact with the Higgs field and so has no mass, while other particles do interact, and so passing through the Higgs field slows them down, and we call the "coupling constant" the mass. :wink:
Mass is a property of matter. "Stuff" usually means matter. Mass can be measured in different ways. One is to see how much it resists acceleration, another is to see how it accelerates other "stuff" towards it. Ultimately is boils down to comparing a mass with a known standard mass that lives in Paris.
Mass is condensed energy.
Seconded.
To add on: that curves space-time.
Fightfish said:
Seconded.
Are you certain of this? Consider that you will never find energy "by itself", but only as a property of another particle or a field with respect to something else.
Also, please tell me how you can condense something that's definition is "the ability to perform work".
This is probably not technically right but how about the ability to resist change in
velocity.
Quite so: I would say that mass is a property of bundled or condensed energy.
Formerly mass was defined as "amount of matter", but if taken literally then that only works well in approximation. For example, if you put several atoms together in a molecule, technically you still have the same amount of matter but the molecule has slightly less mass than the separate atoms.
- http://www.phys.unsw.edu.au/einsteinlight/jw/module5_binding.htm
I meant to agree with the notion of mass being a form of "trapped" or "localised" energy. That's how I tend to see it; though to me it is also sometimes a proportionality constant of sorts in classical mechanics.
If you're asking what it is by trying to figure out what causes it, I think that's still an open question, and one of the theories is the Higgs Boson. But that's all speculation.
light could be thought of condensed energy and it has no mass.
The key word here is rest mass. Light has mass when moving at speed c, it just has no rest mass. Anyways, anything with energy must necessarily have mass.
ok very good. Ya I forgot about the difference between relativistic mass and rest mass and like effective mass .
It's better to just drop "relativistic mass" and use momentum instead. Energy contributes to gravity so everything still works fine. Photons have no mass, ever!
mass is not constant , it depends on gravity . W = M.g so , i want to ask , if we are on the vacuum room , is our mass becoming zero ?
First, you're talking about weight, not mass, here. Assuming you haven't done any Special Relativity, we'll assume Newtonian Mechanics here.
Mass is constant in Newtonian Mechanics. Weight, [itex]\displaystyle W=m\cdot g[/itex], where [itex]g[/itex] is acceleration due to gravity. If we're in a room with no air in it (assuming we could survive this), our weight is not zero. Gravity can still affect people through a vacuum. Example: Astronauts on the Moon.
how about if we are on room with no gravity ?
If you have no gravity then you have no weight, but you most definitely still have mass. It's still harder to push a 10 kg block than a 1 kg block while weightless.
if mass is energy and gravity also package of energy called graviton , i just make a conclusion if mass have positive charge and graviton have negative charge . if we make conclusion like that , so electron can not affected by gravity , isn't it ?
I have no idea why you are making those conclusions. They are 100% incorrect. Mass isn't energy, gravitons have never been observed, and mass having a + charge with gravitons having a - charge doesn't work or make any sense with how the universe works.
i am sorry for my conclusion .
so , if not energy what is the most specified thing to describe what is mass ?
is mass depends on the speed of light ?
i just read about one formula
m' = m/ ((1- (v/c)^2)) ^0.5
There is no easy definition as to what mass is. See here: http://en.wikipedia.org/wiki/Mass
No, our unit of measurement for mass, the kilogram, is set by us. The speed of light has nothing to do with it.
I'm not quite sure what that formula is for. Where did you find it?
i forget where i found that formula , i will find it later, i just remember it just explained if mass depends by c , if mass move with speed same with c , we can conclude if that thing has infinite mass . that is paradox of quantum physics
I'm pretty certain that's the Relativistic Formula for mass.
I think what you are talking about is the energy required to accelerate an object to a speed. The velocity of an object can never reach c because it would take an infinite amount of energy to accelerate it to c. AKA it can't happen. The mass of a moving object does not increase. In it's own frame the object will always have the same mass.
Not sure, I've never seen it before. (Which isn't saying much, I haven't studied physics)
That formula is the so-called "relativistic mass" and is no longer used, because it is just equal to [itex]\frac{E}{c^2}[/itex]. Mass of an object is the unprimed m in the formula and is invariant. As Drakkith said, the energy increases with speed, not mass.
hi kevinsetiono! :smile:
the gravitational field is not made of gravitons, you might as well say that a magnetic field is made of photons :redface:
the mass (your " m ", the mass something has when stationary) of a particle has nothing do with c
the "relativistic mass" (your " m' ") is the rest-mass times a factor that depends on v/c
the mass of a particle depends only on how strongly it couples to the higgs field
kevinsetiono said:
… if mass depends by c , if mass move with speed same with c , we can conclude if that thing has infinite mass . that is paradox of quantum physics
yes, but that has nothing to do with quantum physics, only with relativity
and there's no paradox, since it can't move with speed c :wink:
hello tiny tim
i still don't understand about rest mass, can you give me the referral links ?
is magnetic field made of photon ?
  • · Replies 22 ·
  • · Replies 46 ·
