Understanding Hydraulic Resistance: A Comparison to Electrotechnics
  • Context: Undergrad
  • Thread starter Thread starter Yuri B.
    Hydraulic Unit
The discussion revolves around the comparison of hydraulic resistance to electrical resistance, exploring the principles and measurements associated with both. Participants examine the analogies between the two systems, questioning the existence of a specific unit for hydraulic resistance similar to Ohms in electrotechnics.
  • Some participants propose that hydraulic resistance can be analogously defined using pressure and flow rate, similar to Ohm's law in electricity.
  • Others argue that the analogy breaks down because electrical resistance is typically constant, while hydraulic resistance may vary with flow conditions.
  • A participant highlights that the resistance of a copper wire can be known without additional variables, unlike hydraulic resistance, which requires knowledge of pressure.
  • There is a question raised about how the resistance of copper wire is determined, suggesting reliance on established knowledge or measurements.
  • One participant reflects on the qualitative differences between the flow of electrons and fluids, indicating a complexity in measuring hydraulic resistance that does not exist in electrical resistance.
Participants express differing views on the nature of resistance in hydraulic systems compared to electrical systems, with no consensus reached on the validity of the analogies or the existence of a unit for hydraulic resistance.
The discussion reveals limitations in understanding hydraulic resistance, particularly regarding how it is measured and defined in comparison to electrical resistance, without resolving these complexities.
Yuri B.
For better understanding of it's principles, electrotechnics is often compared to hydronics (and, probably, vice versa).
But, why having the electrical resistance to a flow of charged particles - with it's basic unit "Ohm", there in general Physics is no unit of measurement of the hydronic resistance to a fluid flow ?
If you consider the analog version of ohm's law, you can quickly define a resistance's units.
If you allow pressure (N/m^2) to represent voltage, and volume flow (m^3/s) to represent current flow, then you can find an analog resistance as:
[itex]R = \frac{V}{I}\;\;--->\;\; R_{hydraulic} = \frac{\frac{N}{m^{2}}}{\frac{m^{3}}{s}} = \frac{N*s}{m^{5}}[/itex]
Your formula implies flow, implies pipe's resistance change with the flow. But, as is known, electrical resistance is constant (so far as there takes place no essential changes in temperature). Such analogy for hydraulic resistance, seen in this respect, seems not to exist there.
No, it does not imply the pipe's resistance changes with flow. It implies for any two given constant variables, you can know what the third is.
If I define electrical resistance the same way, then you would have to argue that it implies resistance changes with current flow, which is not the case.
We know aforehand the resistance of, for instance, a 1 m long 1mm diameter copper wire as 0.0263 Ohm, without resorting to other variables.
But we do not know resistance to flow of, for instance, a 1 m long 1 mm hydraulic dyameter copper pipe, without referring to pressure.
How do we know the resistance of the copper wire beforehand?
The resistance to direct current of a 1 m long 1mm diameter copper wire is 0.0263 Ohm, independent of a current flowing through it or a voltage applied, so far as its temperature does not change.
Yes, but how do we know what that resistance is? Someone who sells the copper tells us what it is?
An electrician knows, and choses the wire correctly.
(I am not telling a plumber does not know his business, I am just wondering there is no unit in qwestion).
How does the electrician know?
Edit: To cut to the point, do you know how electrical resistance is measured?
I can see now: there is no "qualitative" difference among "imaginary" electrons flows, but countless ones among "real" fluids flows. So would have been the "resistances" - in the latter case.
Thank you, DragonPetter for making me to think for a while.
  • · Replies 16 ·
  • · Replies 18 ·
