| New Reply |
Question about MOND and gravity |
Share Thread |
| May2-12, 10:53 AM | #1 |
I'm trying to figure out the formula adjustment to Newtonian mechanics using MOND but I'm getting stuck. Wikipedia states:
"Assuming that, at this large distance r, a is smaller than a0 so: μ × (a/a0) = a/a0" Why does 'a' being smaller than 'a0' get rid of μ? |
| May2-12, 11:02 AM | #2 |
In MOND, μ(x) is actually defined to be a function of x such that μ(x) = 1 when x is much larger than 1 and μ(x) = x when x is around 1 or smaller. |
| May2-12, 11:23 AM | #3 |
I am not very familiar with functions like this. That makes more sense
So what is μ? |
| May2-12, 11:40 AM | #4 |
Question about MOND and gravityFor illustration purposes, you could for example use μ(x) = x/(1+x). The whole idea of a function which effectively cuts off the effect at a certain acceleration is very odd anyway. MOND is typically used to describe how stars move when in a very weak gravitational field at the edge of a galaxy, but if you consider the atoms within the star, they are all subject to much greater accelerations due to the star itself. This seems to require some sort of magic whereby the motion of the star as a whole is not the same as the average motion of its component atoms. |
| May2-12, 11:50 AM | #5 |
The idea behind MOND is to insert a fudge factor into the gravity equations and see if you can get the observed behavior of galaxy rotation curves. Now if it turned out that there was some pattern in that fudge factor, you could then start thinking about what that fudge factor could be. But it hasn't worked out. It turns out that every galaxy seems to have a different fudge factor, which makes dark matter a more convincing explanation for what is causing the rotation curves. There's something one of my advisors called the "tooth fairy rule." Which is that in any theoretical astrophysics paper, you are allowed one wave of the tooth fairy's magic wand. If you assume one crazy thing and if everything works, you win. Dark matter is another tooth fairy, but you just wave it once and lots of problems disappear. The problem with MOND is that right now you need to wave the magic wand several times. |
| May2-12, 11:58 AM | #6 |
| May2-12, 12:02 PM | #7 |
The dark matter theory seems a little shaky too though with it's "halo" and in essence is just another 'fudge factor' is it not to preserve Newtonian Mechanics? |
| May2-12, 02:14 PM | #8 |
| May2-12, 03:15 PM | #9 |
The really weird thing about MOND is that it actually works for a huge range of different galaxies using the same a0 value, and correctly predicted the results for Low Surface Brightness (LSB) galaxies before any measurements had been made on them. However, it doesn't work at larger scales (such as galaxy clusters and interacting galaxies) nor at smaller scales (globular clusters within galaxies) without further tweaking. |
| May2-12, 03:22 PM | #10 |
http://www.scilogs.eu/en/blog/the-da...s-far-too-well
Pavel Kroupa is highly enthused over MOND. Respectfully submitted, Steve |
| May2-12, 03:30 PM | #11 |
| May2-12, 04:00 PM | #12 |
As far as I know, MOND is extremely successful on the scale of galaxies. The problem is mainly that it is simply an arbitrary rule which has been found to work experimentally, while attempts to find an underlying theory behind it have not been very convincing; even though progress has been made, for example with TeVeS, some of the concepts still seem to violate fundamental physical principles.
Calculations on the scale of galaxies are typically done using mainly Newtonian gravity theory, with the occasional check to ensure that General Relativity effects are small enough to ignore in specific cases. |
| May2-12, 04:47 PM | #13 |
| May2-12, 05:24 PM | #14 |
Anyone know how to run the calculations for MONDS? In DMT (dark matter theory) it looks like they are just using a certain mass of dark matter outside the galaxies to account for the discrepancies in velocities of the stars and to preserve the laws of gravitation. Does that sound right? |
| May2-12, 05:31 PM | #15 |
| May2-12, 08:30 PM | #16 |
But things can change. |
| May2-12, 08:38 PM | #17 |
The trouble is that the main reason people think that there is dark matter has to do with large scale cosmology which Kroupa doesn't talk about. Basically in order to get the right lumpiness factor and deuterium abundances, you have to assume dark matter. Modified gravity theories don't quite work in that context. One reason for this is that things go in the wrong direction. With dark matter, the denser things are, the weirder things get, whereas with modified gravity, you end up with things getting weirder the less dense things get. This matters for things like deuterium abundances. Look at point 9) that Kroupa makes. In order to get the CMB distributions with MOND he has to assume a 11eV sterile neutrino. That's fine, but 1) sterile neutrinos are dark matter and 2) that's another wave of the magic wand, and it's not a small wave. Once you put in a new particle, then you have to recalculate all of the big bang nucleosynthesis numbers. What Kroupa is saying is that MOND + a hypothetical particle makes everything work. Trouble is that you can get everything to fit by dropping MOND and just assuming a hypothetical particle, and you save one wave of the magic wand. |
| New Reply |
Similar Threads for: Question about MOND and gravity
| A question on Gravity Waves and Gravity Radiation | Cosmology | 3 | ||
| Question about dark matter, dark energy, and MOND | General Physics | 24 | ||
| Could gravity's strength also require denisty as an alternative to MOND | Astrophysics | 1 | ||
| Random MOND theory / dark matter question(possibly really easy to answer) | Astrophysics | 4 | ||
| MOND gravity, an explanation please. | Cosmology | 3 | ||
