How are sources of AC power matched in a common grid?
The discussion centers on how sources of AC power are synchronized when connecting to a common electrical grid. It explores the technical aspects of phase matching and synchronization methods for both large generators and smaller systems like home photovoltaic setups.
  • One participant questions how AC power sources are matched in phase when joining a common grid, specifically mentioning the importance of synchronization at 60 hertz.
  • Another participant explains that for large generators, synchronization can be observed using light bulbs that indicate phase alignment, suggesting that bulbs dim as phases approach synchronization.
  • A different participant suggests that using a synchroscope is a better method than light bulbs for determining synchronization.
  • There is mention of home photovoltaic systems where the inverter synchronizes the AC output with the grid without moving parts, producing AC in phase with the grid.
Participants present various methods for synchronization, indicating that there are multiple approaches to the problem. However, there is no consensus on the best method, as different participants advocate for different techniques.
The discussion does not resolve the specifics of synchronization methods or the effectiveness of the proposed techniques, leaving some assumptions and technical details unaddressed.
This discussion may be useful for individuals interested in electrical engineering, power generation, or those exploring the integration of renewable energy systems with existing power grids.
LawrenceC
Not being an electrical engineer, I have always wondered how sources of AC power are matched when joining a common grid. I assume the power is generated at 60 hertz from each source but how is the match made so sources are in phase with one another?
For instance, suppose an individual could generate his own electrical power. I have heard of the situation where the unneeded power is passed to the utility company for a credit. I assume the phases must be synchronized. How is this done?
This was explained well in a thread a few weeks back. I can't find it though. For big generators: Basically, you set your generator running at precisely the right speed, and connect a light bulb between your RED phase and the grid's RED phase, and same for YELLOW phases. When the phases are nowhere near synchronized, the bulbs glow steadily. As the phases approach sync the bulbs brightness glows and dims periodically, with a longer and longer period as you approach sync. When the speeds and phases are perfectly in sync, the bulbs are unlit. That's the point at which you connect the two systems.
For you home photovoltaic system: there are no moving parts. The inverter that converts the DC to AC is synchronized to the grid and produces its AC in phase. It's not a 3 phase system.
Instead of using light bulbs it is better to use a synchroscope, (google it for details).
Thanks for replies.
