What level hazmat suit should be worn while tending to Uranium-238
  • Thread starter Thread starter sean888
The discussion revolves around the appropriate level of hazmat suit required for handling Uranium-238, focusing on safety measures related to its alpha radiation and chemical properties. Participants explore the necessary protective gear for different scenarios, including direct handling and potential dust generation.
  • Some participants suggest that handling Uranium-238 at arm's reach may only require a lab coat and goggles, given that it primarily emits alpha radiation.
  • Others mention that when handling enriched uranium compounds, thin gloves and a lab coat were sufficient, but they also note the importance of using a dust mask or working under a hood if dust is produced.
  • Questions are raised about the use of a level B hazmat suit, with some participants inquiring whether it provides radiation protection or is solely for preventing chemical burns and injuries.
  • It is noted that alpha particles from U-238 are absorbed by gloves, and the gamma radiation is low, suggesting that the material's density offers self-shielding.
  • One participant emphasizes treating U-238 chemically like lead or other heavy metals, recommending avoidance of skin contact and washing off any accidental contact.
Participants express varying opinions on the necessity and type of protective gear for handling Uranium-238, indicating that multiple competing views remain without a clear consensus on the best practices.
Participants do not fully resolve the conditions under which different levels of protection are necessary, nor do they clarify the specific circumstances that would dictate the use of a level B hazmat suit versus other protective measures.
sean888
If you were to be handling Uranium-238 at arms reach what would you where? I know it is only alpha radiation, but would you need something other than a hazmat suit, like more protective or do you only need a lab coat and goggles.
I have handled enriched uranium compounds, and I only needed thin gloves and a lab coat.
If one is doing something where dust might be produced, then one can were a dust mask or work with the sample under a hood.
When would you use let's say.. a level B hazmat suit? Is there any protection against radiation or is it just to prevent chemical burns and other associated injuries?
If one was using a compound that is gaseous, but the one would probably use a hood. The alphas from U-238 are absorbed by the gloves and the gamma activity is low. U-238 is pretty dense, so it provides a lot of self shielding.
Chemically, it should be treated like lead or other heavy metal. One simply avoids contact, but if it contacts the skin, wash it off.
  • · Replies 83 ·
19K
  • · Replies 36 ·
  • · Replies 16 ·
  • · Replies 18 ·
