Solve Rope Physics Problem: Find Time to Travel Length of Rope
  • Thread starter Thread starter DMD
    Stuck
The time required for a transverse wave to travel the length of a rope, when whirled in a horizontal circle, is determined by the formula T = L*sqrt(L/R). This solution derives from the relationship between wave speed, tension, and linear density, where the tension is equal to the centripetal force acting on the rope. The calculations involve using the equations v = sqrt(F_tension/µ) and F_tension = m*v^2/R, leading to the conclusion that the wave speed is v = sqrt(v^2*R/L). The final expression for time incorporates the rope's length and radius of the circular motion.
  • Understanding of wave mechanics and wave speed equations
  • Familiarity with centripetal force and tension in rotating systems
  • Knowledge of linear density calculations (µ = m/L)
  • Basic grasp of angular velocity and its units
  • Study the relationship between tension and centripetal force in rotating systems
  • Learn about wave propagation in different mediums and its mathematical modeling
  • Explore the concept of linear density and its applications in physics
  • Investigate the implications of angular momentum in rotational dynamics
Physics students, mechanical engineers, and anyone interested in the dynamics of rotating systems and wave mechanics.
DMD
Here's the problem:
A uniform rope with length L and mass m is held at one end and whirled in a horizontal circle with angular velocity omega. You can ignore the force of gravity on the rope. Find the time required for a transverse wave to travel from one end of the rope to the other.
So far by fiddling with some equations, I've got:
F_tension = ma = m*L*omega^2
µ = m/L
v = sqrt((m*L*omega^2)/(m/L)) = sqrt(omega^2*L^2) = omega*L
And of course, that gets me nowhere except another textbook equation, namely v = R*omega
So I have no idea where to go from there.
Any help will be appreciated.
Your equations look a bit fishy. For example, your last relation v=L*omega implies that the units of angular velocity are just meters, which isn't correct. Maybe you can relate L (angular momentum) in terms of distance L and linear density lambda and omega (or one of its derivatives?) by using the moment of inertia. Once we know the velocity, we already have the length, so the time it takes for a wave to travel down the rope's length should be easy. g'luck!
To solve this problem, we can use the formula for the speed of a wave, v = sqrt(F_tension/µ), where F_tension is the tension in the rope and µ is the linear density of the rope. We can also use the fact that the speed of a wave is equal to the wavelength divided by the period, v = λ/T.
First, let's find the tension in the rope. We know that the tension in the rope is equal to the centripetal force, F_c = m*v^2/R, where m is the mass of the rope, v is the speed of the rope, and R is the radius of the circle. Since the rope is being whirled in a horizontal circle, the centripetal force is provided by the tension in the rope, so F_c = F_tension. Therefore, F_tension = m*v^2/R.
Next, we need to find the linear density of the rope, µ. This can be calculated by dividing the mass of the rope by its length, µ = m/L.
Now, we can substitute these values into the equation for the speed of the wave, v = sqrt(F_tension/µ). This gives us:
v = sqrt((m*v^2/R)/(m/L))
Simplifying, we get:
v = sqrt(v^2*R/L)
Finally, we can use the equation for the speed of a wave, v = λ/T, and substitute in the speed we just found, v = sqrt(v^2*R/L), to solve for the period, T:
v = λ/T
sqrt(v^2*R/L) = λ/T
T = λ/sqrt(v^2*R/L)
Since the wavelength, λ, is equal to the length of the rope, L, we can substitute that in:
T = L/sqrt(v^2*R/L)
T = L*sqrt(L/R)
Therefore, the time required for a transverse wave to travel from one end of the rope to the other is T = L*sqrt(L/R). This is the final solution to the problem.
  • · Replies 19 ·
  • · Replies 22 ·
  • · Replies 39 ·
  • · Replies 26 ·
