Manifold Explained in Simple Terms
  • Context: Undergrad
  • Thread starter Thread starter KFC
    Manifold
The discussion revolves around the concept of 'manifold' as it appears in contexts such as statistical physics and classical mechanics, particularly in relation to phase space. Participants seek to clarify the definition and understanding of manifolds, exploring both simple explanations and more formal definitions.
  • One participant describes an n-dimensional manifold as a representation of non-Euclidean space that is locally Euclidean at any point, suggesting that local coordinate systems can be defined.
  • Another participant proposes that a manifold can be thought of as a set of objects described by coordinate charts, emphasizing the mapping to Euclidean space R^n.
  • A participant questions whether the previous definition pertains specifically to differentiable manifolds rather than manifolds in general, indicating a potential assumption about differentiability.
  • Further clarification is provided regarding the formal definition of a manifold as a topological space with specific properties related to open sets and continuous functions.
  • Concerns are raised about the completeness of definitions, particularly regarding the requirements for homeomorphisms and differentiability in the context of manifolds.
  • Examples are suggested as a means to illustrate the concept, such as mapping the surface of the Earth to flat maps through overlapping regions.
Participants express differing views on the definitions of manifolds and differentiable manifolds, indicating a lack of consensus on the precise nature of the explanations provided. Some seek simpler illustrations while others delve into more technical definitions.
There are unresolved questions regarding the assumptions made about differentiability and the completeness of the definitions provided. The discussion reflects varying levels of understanding and the complexity inherent in the topic.
KFC
Hi there,
I find that the term 'manifold' appears in many book of statistical physics or classical mechanics while talking about phase space. I try to search the explanation on online but it is quite abstract and hard to understand what's manifold really refers to. Can anyway explain this a bit with a simplest picture? Thanks
An n-dimensional manifold, in simplest terms, is a representation of non-Euclidean (in general) n-dimensional space that is locally Euclidean* at any point. In other words, you can define a local coordinate system anywhere, but not necessarily a global coordinate system.
Keep in mind, I am oversimplifying a bit. For formal definition, look up pretty much any topology text.
One can think of a Manifold as any set of objects which can be described by a set of coordinate charts (called an atlas). A coordinate chart is a mapping between your set of objects to some Euclidean space R^n (n is then the dimension of your manifold). There's really nothing much more to it than that. If you can describe your set of objects in such a way, then it's a manifold.
I am a bit confused. Isn't it the "definition" of differentiable manifold instead of manifold?
Could be. Did I make an assumption that mapping is differentiable when I said that coordinate system could be defined? I think you might be right about that. I'm sure the OP would be dealing with such, but I probably shouldn't have defined it so narrowly anyways. Matterwave's explanation is a lot closer to a formal, general definition of a manifold.
A "manifold" is a geometric object that is locally Euclidean. More precisely, an n dimensional manifold is a topological space, together with a set of "pairs", [itex]\{(M_\alpha, \phi_\alpha)\}[/itex], in which one member of each pair, [itex]M_\alpha[/itex], is an open set and the other member, [itex]\phi_\alpha[/itex], is a continuous function from [itex]M_\alpha[/itex] to Rn.
We require, further, that if p is any point in the manifold there exist at least one [itex]\alpha[/itex] such that p is in [itex]M_\alpha[/itex] ( the open sets cover the manifold). We require, further, that in the intersection of two such sets, [itex]M_\alpha[/itex] and [itex]M_\beta[/itex], [itex]\phi_\alpha o\phi_\beta[/itex] be a homeomorphism from Rn to itself.
In order to have a differentiable manifold, we require that, in the intersection of [itex]M_\alpha[/itex] and [itex]M_\beta[/itex], both [itex]\phi_\alpha o \phi_\beta[/itex] and [itex]\phi_\beta o\phi_\alpha[/itex] be differentiable.
Halls, OP states that he looked at former definitions. I think he was looking for a simpler illustration.
If 'o' here just means the usual composition of functions, there's some inversion missing. But then the functions must be 1-1 onto.
As I read it, the individual functions are required to be homeomorphisms. The composition of one with the inverse of another then is automatically a homeomorphism.
Going back to the original question, maybe some examples help. The mapping of the surface of the Earth to flat maps by carving it into overlapping regions is an obvious one.
14K
  • · Replies 28 ·
  • · Replies 38 ·
9K
  • · Replies 50 ·
  • · Replies 23 ·
  • · Replies 131 ·
14K
