Circular motion-what is the radius of the loop de loop in meters
The problem involves a scenario where Snoopy is flying a vintage warplane in a circular path, specifically a "loop de loop." The context includes his speed at the bottom of the loop and the reading on bathroom scales indicating he weighs four times his normal weight. The objective is to determine the radius of the loop.
  • Participants discuss converting speed from km/hr to m/s and the implications of the weight reading on the scales. There are attempts to apply centripetal acceleration and force equations, with some expressing confusion about the relevance of certain forces and how to approach the problem.
The discussion is ongoing with various participants exploring different aspects of the problem. Some have suggested focusing on the forces acting on Snoopy, while others are questioning the assumptions made regarding mass and acceleration. There is no explicit consensus, but several participants are providing guidance on identifying relevant equations and forces.
Participants are grappling with the implications of the weight reading and how it relates to the forces acting on Snoopy during circular motion. There is a noted lack of clarity regarding the mass of Snoopy and how it factors into the calculations, as well as confusion about the necessary equations to use.
dani123
Snoopy is flying his vintage warplane in a "loop de loop" path being chased by the Red Baron. His instruments tell him the plane is level (at the bottom of the loop) and traveling at 180 km/hr. He is sitting on a set of bathroom scales that him he weighs four times what he normally does. What is the radius of the loop in meters?
Fc=mv2/R
ac=v2/R
I am completely lost with this problem but this is what I attempted...
I started by converting 180km/hr into m/s and came up with 648 000 000m/s.
Then I used this value and plugged it into the centripetal acceleration equation and used ac=9.8m/s2 and then solved for R= 4.28*1016m
I know this must be the wrong answer but I am very lost as to what I should do or even how I should be looking at this problem... If anyone could help me out that would be greatly appreciated! Thank you so much in advance!
hi dani123! :smile:
:smile: :smile: :smile:
hint: what is the equation for the reaction force between snoopy and the scales? :wink:
im confused as to how that's going to help me find the radius..
but the only information you have is the magnitude of that reaction force :confused:
so do i just convert 180km into meters?
nvm! scratch that last post ...
yes, and hours into seconds :smile:
i tend to over think the problems that have the simplest answers! haha
after i converted it into m/s... that's the answer? really?
That's the answer to his speed in m/s. It doesn't answer the question about the radius of the loop he's following.
Consider what his effective acceleration must be if he weighs 4x normal weight (when the usual acceleration due to gravity is just g). What additional acceleration is operating when he moves in circular motion?
im lost
i don't know anymore,, I am really confused
edit...delete
If the radius were infinite, there would be a 1g upward force exerted by the scale on him. How many additional g's of force are required to keep him moving in a circle? That should be v2/R.
Chet
well, how many forces are there, and what is the acceleration?
The net force is 3g's.
how did you come up with these g's ?
What is the radius of the loop in meters?You draw a free body diagram. From this you can calculate the radius needed.
There are 3 forces exerted on the man.
1. Gravitional force.
2. Centripetal force.
3. Normal force. This force shown by the scale.
There are only two forces on Snoopy: the gravitational force and normal force. The net force on Snoopy results in his centripetal acceleration.
ok i understand that, but to calculate the forces don't i need Snoopy's mass?
yes, but call it "m" …
when you calculate the speed or the radius, "m" will cancel out in the end :wink:
could someone show me which equations to use please? i have a list of them in front of me and I am lost as to which ones i should be focusing on
dani123 said:
i have a list of them in front of me …
show us :smile:
ac=V2/R
ac=4∏2R/T2
Fc=m*4∏2*R/T2=m*V2/T2
μ=Ff/Fn
average speed:V=2∏R/T
Fnet=m*a
Fc=m*V2/T2
Fc=m*V2/R
Fncos(θ)=m*g
Fc=Fn*sinθ
This is what I got...
for the third time …
what is the equation for the reaction force between snoopy and the scales?​
Fnet=m*a?
dani123 said:
Fnet=m*a?
yes :smile:
and what forces is Fnet made of?
mass and acceleration? which i don't have...
That's not what Tim was asking for. Neither mass nor acceleration is a force. Fnet is the sum of all of the forces exerted on Snoopy. Identify all the forces on Snoopy and add them up. That's the lefthand side of the equation. The righthand side is simply ma.
You should also be able to identify a relevant expression for Snoopy's acceleration since you were given that he's moving in a circle. Put this all together and you have the equation you need to solve.
  • · Replies 19 ·
9K
  • · Replies 21 ·
