Can the Attractive Force Between a Metallic Object and a Magnet be Quantified?
  • Context: Undergrad
  • Thread starter Thread starter Cluelessness
    Magnet Magnetic
The attractive force between a metallic object and a magnet can be quantified, but it primarily applies to ferromagnetic materials such as iron. Non-ferromagnetic metals exhibit negligible magnetic attraction, making quantification impractical. To measure the force, specialized equipment and formulas are necessary, particularly for ferromagnetic objects. Understanding the material properties is crucial for accurate measurement.
  • Basic understanding of ferromagnetism and its properties
  • Familiarity with magnetic field concepts
  • Knowledge of measurement tools such as force gauges
  • Understanding of relevant formulas for calculating magnetic force
  • Research the properties of ferromagnetic materials and their behavior in magnetic fields
  • Learn about the use of force gauges for measuring magnetic attraction
  • Study the formula for calculating the magnetic force between a magnet and a ferromagnetic object
  • Explore experimental setups for quantifying magnetic forces in a laboratory setting
Physicists, materials scientists, and engineers interested in magnetism and its applications in technology will benefit from this discussion.
Cluelessness
This may be a dumb question but I am so lost and would appreciate any help!
Is there a way to quantify the attractive force between a metallic object and a magnet?
With numbers not qualitatively? I was under the impression that with a metallic object everything was microscopic so itd be impractical..
but is there a way? formula or equipment?
Please help me and thank you so much in advance
It is possible, but in general it is tricky to do.
I don't think that "metallic object" is what you are looking for - if it is not ferromagnetic, the force is usually negligible. Many metallic objects in daily life are made out of iron, which is ferromagnetic, but most metals are not.
13K
