Change of Phase and Latent Heat
The discussion revolves around the concepts of phase changes and latent heat, specifically focusing on the behavior of water as it transitions between solid (ice), liquid (water), and gas (steam) states. Participants are exploring why temperature remains constant during these phase changes despite the addition of heat.
  • The original poster questions why the temperature does not increase when heat is added to water at its boiling point or to ice at 0 degrees Celsius. Some participants attempt to clarify that energy is used for breaking intermolecular forces rather than increasing temperature during these phase changes.
Participants are actively engaging with the original poster's questions, providing explanations about the energy dynamics involved in phase changes. There is a focus on the distinction between temperature changes and energy absorption during state transitions, but no consensus has been reached regarding the original poster's phrasing or understanding of the scenarios.
The discussion includes assumptions about the behavior of water at critical temperatures and the nature of energy transfer during phase changes. The original poster expresses concern about the clarity of their question, indicating potential confusion in the framing of the problem.
Soaring Crane
I am trying to word this question as best as I can.
Once water has reached its bottom-notch state/position, will the temperature increase?
I mean, if water changes to steam once heat is added, why won't the temp. increase (or stay constant)?
Another question is why won't the temp. rise if heat is added to ice when 0 degrees Celsius is reached?
Thanks again, and I'm sorry if I worded this confusingly.
The answer to your question is that ( for ice let's say ) if the temp is below 0 degrees celsius then all of the energy from the heat source is going into raising the temperature ( ie magnifying the vibrations of the water molecules ) however once 0 degrees is reached the molecules obtain enough energy to break free from each other, that is all the energy from the heat source goes into breaking the IMF between them, so in a sense the temp doesn't increase because all of the energy goes into breaking the bonds between the molecules. Once all of the molecules have broken free ie: ice into water, the temp will continue to increase.
What about the first scenario with steam?
Did I word it incorrectly?
The same argument goes only now the "before" state and "after" state has changed ( ie water to steam ) as well as the critical temp. Once the temp at which water boils (100 deg Cel. ) is reached, All the energy provided by the source of heat goes into changing the state of the substance, ie: breaking the bonds completely between the water molecules thus forming a gas. Thus this argument can be applied to ANY state change of the substance,,,, the temp rises, then at the critcal point whether its the MP, BP, FP, or whatever the energy goes into the formation/breakage of bonds.
