What is the purpose of the Fortran 77 DECK statement?
  • Context: Fortran
  • Thread starter Thread starter jf22901
    Fortran
The discussion centers around the purpose and meaning of the DECK statement in Fortran 77 code, particularly in the context of older subroutines used in a weather forecasting model. Participants explore its potential significance and origins, as well as its relevance to modern coding practices.
  • Historical
  • One participant notes the presence of DECK and *DECK in subroutines but finds no references to it in Fortran documentation, expressing uncertainty about its meaning.
  • Another participant suggests that *DECK is a comment and questions the meaning of DECK without a preceding character.
  • A participant proposes that DECK may be a directive related to a source-code management system called NUPDATE, used in the UK, particularly in meteorological contexts.
  • Further discussion reveals that DECK directives might not be standard Fortran and could be specific to the codebase from which the subroutines originate.
  • One participant mentions that the DECK directives can likely be deleted unless they are needed for a specific system.
  • Another participant humorously reflects on the historical context of file management systems, suggesting that DECK directives may date back to earlier computing practices.
Participants generally agree that DECK is not a standard Fortran statement and that its usage may be specific to certain systems or historical practices. However, there is no consensus on its exact purpose or necessity in the code.
Participants acknowledge that the DECK statements appear in subroutines that call additional subroutines, suggesting a possible structural or organizational role, but the implications of this are not fully resolved.
jf22901
Hi all.
I am using some Fortran 77 code that was originally written in the early 90s, and some of the subroutines start with DECK or *DECK. I have tried searching the internet but cannot find anything relevant. As an example, say the main program calls two subroutines SUBONE and SUBTWO. One of these subroutines is of the form
Code:
DECK SUBONE1
      SUBROUTINE SUBONE(arguments)
      <code for rest of subroutine follows>
and the other is of the form
Code:
*DECK SUBTWO1
      SUBROUTINE SUBTWO(arguments)
Can anyone enlighten me to what the DECK statement is for, and why some subroutines have an asterisk in front of it? I'm guessing that the 'SUBONE1, SUBTWO1' is the name of the relevant 'DECK', but that's as much as I can work out!
Thanks in advance. :smile:
Technology news on Phys.org
As far as I know, there is no DECK statement in Fortran. I couldn't find any reference to it in a web search. In your second example, the line with *DECK in it is a comment. If DECK appears without a preceding * or C, as you show, I have no idea what it means.
Thanks Mark.
Good to know it wasn't just my useless web searching skills! :smile:
The code all compiles ok, so it's not as if they are causing a problem - I was just wondering what they were there for. After a further look, the DECK statements only appear in subroutines that call additional subroutines. The code is from an old weather forecasting model, so it might be something specific they have added themselves, and not a standard Fortran thing.
Thanks again.
jtbell said:
DECK appears to be a directive for a source-code management system called NUPDATE that was (maybe still is) used in the UK, e.g. at the Department of Meteorology (aha!) at Reading:
http://www.met.reading.ac.uk/~mike/dyn_models/nupdate/nupdate_doc.txt
Thanks jtbell, that's brilliant! It's an old UK Met. Office model I'm using (to model Mars' atmosphere), and I guess it was developed partly at Reading.
How did you stumble on that website? I tried loads of search combinations and still found nothing!
It comes out at the top of a search for "fortran deck directive". I figured "directive" might be an appropriate generic term for it, since it's not an actual FORTRAN statement.
You can probably simply delete those DECK directives, unless you're using a system that actually uses them.
Or, put the code that follows
*DECK foo
in file foo.f, if you want to preserve the original file structure for some reason.
This stuff probably dates from when a "file system" was a big metal rack full of trays of punched cards, with about 2000 cards per tray, not something on a thumb drive.
16K
  • · Replies 18 ·
11K
  • · Replies 25 ·
9K
