New Reply
I need help in programing in FOTRAN 90
Share Thread Thread Tools
May7-12, 04:16 PM   #1
Hi
I have written a program in FOTRAN for solving special system called Tridiagonal system
has 5 equation
I'm in the learning stage of FOTRAN 90
and this my program::
Please help me
program triiagonal
implicit none
real, dimension A(5,5),B(5,5),f(5),X(5)
integer::n,i,j,m,k,l,s1,s2
print*,"input the number of element(n)"
read*,n
do i=1,n
do j=1,n+1
print*,"input the matrix a(i,j)"
read*,A(i,j)
end do
end do
m=n*(n-1)/2
do i=2,n
do k=1,n-1
if(A(i,j)/=0)then
do j=1,n+1
A(i,j)=A(i,j)-f(i,k)*A(j,k)
end do
else
do l=i-1,i-1
do j=1,n+1
b(i,j)=a(i,j)
a(i,j)=a(i+1,j)
a(i+1,j)=b(i,j)
end do
end do
end if
do i=n,1,-1
do j=i+1,n
s2=s2+A(i,j)*(j)
end do
s1=a(i,n+1)
x(i)=(s1-s2)/a(i.i)
end program triiagonal
this my error::
C:\Documents and Settings\eXtreme\Desktop\New Folder\ffff\fff.f90
C:\Documents and Settings\eXtreme\Desktop\New Folder\ffff\fff.f90(3): error FOR3852: syntax error detected between DIMENSION and A
C:\Documents and Settings\eXtreme\Desktop\New Folder\ffff\fff.f90(10): error FOR3701: symbol A is not a variable
C:\Documents and Settings\eXtreme\Desktop\New Folder\ffff\fff.f90(18): error FOR3712: symbol A is not an array
C:\Documents and Settings\eXtreme\Desktop\New Folder\ffff\fff.f90(24): error FOR3712: symbol A is not an array
C:\Documents and Settings\eXtreme\Desktop\New Folder\ffff\fff.f90(25): error FOR3712: symbol A is not an array
C:\Documents and Settings\eXtreme\Desktop\New Folder\ffff\fff.f90(29): error FOR3541: duplicated DO index variable - I
C:\Documents and Settings\eXtreme\Desktop\New Folder\ffff\fff.f90(34): error FOR3251: symbol I is not a derived type detected between % and I
C:\Documents and Settings\eXtreme\Desktop\New Folder\ffff\fff.f90(36): error FOR3597: missing 3 END DO statements
C:\Documents and Settings\eXtreme\Desktop\New Folder\ffff\fff.f90(36): error FOR2290: implicit type for X
C:\Documents and Settings\eXtreme\Desktop\New Folder\ffff\fff.f90(36): error FOR2290: implicit type for F
C:\Documents and Settings\eXtreme\Desktop\New Folder\ffff\fff.f90(36): error FOR2290: implicit type for B
C:\Documents and Settings\eXtreme\Desktop\New Folder\ffff\fff.f90(36): error FOR2290: implicit type for A
Your help would be appreciated.
Thanks
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Hong Kong launches first electric taxis
>> Morocco to harness the wind in energy hunt
>> Galaxy's Ring of Fire
May7-12, 04:28 PM   #2
Replace this:
Code:
with this:
Code:
real, dimension(5,5) :: A,B
real, dimension(5) :: f,X
and try again.
May8-12, 01:19 AM   #3
ooooooh no ....... the same errors !!?
May8-12, 07:01 AM   #4
please repost source, use code tags
May8-12, 10:32 AM   #5
Code:
program  tridiagonal
implicit none
read*,n
do i=1,n
 do j=1,n+1
  read*,A(i,j)
 end do
end do
  m=n*(n-1)/2
do i=2,n
 do k=1,n-1
 if(A(i,j)/=0)then
 do j=1,n+1
 end do
 else
do l=i-1,i-1
 do j=1,n+1
 b(i,j)=a(i,j)
 a(i,j)=a(i+1,j)
 a(i+1,j)=b(i,j)
 end do
end do
end if
do i=n,1,-1
do j=i+1,n
  s2=s2+A(i,j)*(j)
 end do
 s1=a(i,n+1)
 x(i)=(s1-s2)/a(i.i)
end program  tridiagonal
my program in attachment ........
File Type: zip fff.zip (425 Bytes, 1 views)
May8-12, 11:04 AM   #6
o.k., so, you did not implement what I suggested...no wonder you are getting the same errors!
May8-12, 02:25 PM   #7
No No ...... This my .... i implemented what you suggested :)
But i am getting the same errors ,,,,,,, so i post the program before Modifying >>
^_^
Please help me ,,,
Bye
May8-12, 03:02 PM   #8
Mentor
Then what does your code look like now?
May8-12, 05:55 PM   #9
jonephy:
please try to be more careful and let it be you who does the double checking of things...we are here to guide you, not to do the work for you.
please double check what you are doing and make sure you implemented the changes I suggested earlier.
also, you have a mess with your do-loops and the loop variables....step back and double check all that; there are also a couple of "end do" missing.
May9-12, 04:18 AM   #10
Thanks all
Ok, i will be more careful
and i will trying to fix all problems in my program
Good Bye
New Reply
Thread Tools
Similar Threads for: I need help in programing in FOTRAN 90
Thread Forum Replies
please help me: a problem on my FOTRAN program Programming & Comp Sci 4
Need in solving a programm in FOTRAN Programming & Comp Sci 3
segmentation fault problem in fotran 90 Programming & Comp Sci 0
Legendre poly in Fotran 90 Programming & Comp Sci 2
Opening an fotran .exe file from Visual Basic Computing & Technology 3
