A diode with a resistor in parallel and in series.
The discussion focuses on a circuit with a diode and resistors, where the diode has a voltage drop of 2V and is paired with a 3kΩ resistor in series (R1) and a 470Ω resistor in parallel (R2). The user is seeking clarification on how to calculate the output voltage and current in the circuit, specifically whether to use 18V (20V supply minus the 2V drop) for calculations. It is confirmed that the voltage across R1 is 18V, allowing for the calculation of current through R2. The user expresses gratitude for the assistance received and acknowledges a newfound understanding of the circuit dynamics.
Trespaser5
I have a diode with a resistor in parallel(R2), but also diode resistor circuit has a resistor in series with it(R1). I have uploaded a drawing as well but I think it takes a bit of time for them to be authorised.
The values of the circuit are
Vs = 20v
R1 = 3kΩ
R2 = 470Ω
Diode = Has a Volt drop of 2v
I've found the formula Vo-Vd/Rl = I for a diode in series in a resistor but am not sure how this relates if the diode also has resistor in parallel with it. I'm guessing from what I've read that the diode does not have a resistance as such but only 'consumes' 2v, so can I use 18v along with the resistance in the remainder of the circuit to calculate It ? Or am I heading down the wrong path entirely. This is my second night on this question so could really do with some help. Thankyou
My .doc viewer isn't working, but I think I can see the circuit. That would be a zener diode, and, yes, it leaves 18V across R1.
Knowing the voltage across R2, you can calculate the current through R2.
Thank you so much. I think I was mis understanding that the voltage drop stated was the same as the voltage shown across, when that twigged today I got it, what a feeling :) Thank you for your help and time :)
Thread 'Have I solved this structural engineering equation correctly?'
Hi all, I have a structural engineering book from 1979. I am trying to follow it as best as I can. I have come to a formula that calculates the rotations in radians at the rigid joint that requires an iterative procedure. This equation comes in the form of: $$ x_i = \frac {Q_ih_i + Q_{i+1}h_{i+1}}{4K} + \frac {C}{K}x_{i-1} + \frac {C}{K}x_{i+1} $$ Where: ## Q ## is the horizontal storey shear ## h ## is the storey height ## K = (6G_i + C_i + C_{i+1}) ## ## G = \frac {I_g}{h} ## ## C...
12K
