| New Reply |
Fortran, why do i suddenly get new errors? |
Share Thread | Thread Tools |
| May9-12, 09:26 AM | #1 |
Sorry for the wrong title!
I currently have a subroutine which should return y like (the actual formula is a bit more complex): y=cos(t) When i call the subroutine and then make a do-loop to test y for different t, it gives 1 value only. Does the subroutine give a value to y or am I doing something else wrong? t doesn't have a value before the subroutine is called. |
| May9-12, 12:48 PM | #2 |
Mentor
Your routine should be a FUNCTION, which does return a value. |
| May9-12, 12:59 PM | #3 |
Code:
call asd(y,t,a) do i=1,10 t=i test(i)=y end do subroutine asd(y,t,a) y=a*cos(t) end Code:
do i=1,10 t=i test(i)=a*cos(t) end do |
| May9-12, 01:11 PM | #4 |
Recognitions:
If your first code you only call the subroutine once. You need to call it inside the loop like this.
Code:
do i=1,10
t=i
call asd(y,t,a)
test(i)=y
end do
Code:
do i=1,10
t=i
call asd(test(i),t,a)
end do
call asd(y,i,a) won't work. (It will probably compile, but give you the wrong answers). |
| May9-12, 01:26 PM | #5 |
| New Reply |
| Thread Tools | |
Similar Threads for: Fortran, why do i suddenly get new errors?
| Errors with fortran code, help! | Programming & Comp Sci | 7 | ||
| What happens to a gas when it suddenly expands? | Classical Physics | 1 | ||
| Fortran 95 Help ( Compiling errors) | Programming & Comp Sci | 3 | ||
| errors in compling fortran | Programming & Comp Sci | 1 | ||
| Accessing Fortran Modules within a Fortran library from Fortran | Programming & Comp Sci | 0 | ||
