What Are the Conditions for an Inflection Point?
  • Context: Undergrad
  • Thread starter Thread starter jd12345
    Condition Point
An inflection point occurs where a curve changes its concavity, specifically when the second derivative is zero. However, the condition of the second derivative being zero is not sufficient for identifying an inflection point. If the third derivative is non-zero at the point where the second derivative is zero, it indicates that the second derivative is either increasing or decreasing, confirming a change in concavity. This concept is illustrated through Taylor series, where the lowest non-zero derivative determines the curve's behavior around the inflection point.
  • Understanding of calculus concepts, particularly derivatives
  • Familiarity with Taylor series expansion
  • Knowledge of concavity and its relation to the second derivative
  • Ability to analyze odd and even derivatives in mathematical functions
  • Study the implications of the third derivative in determining inflection points
  • Explore Taylor series and its applications in curve analysis
  • Learn about higher-order derivatives and their significance in calculus
  • Investigate examples of functions with and without inflection points, such as y = x^4 and y = x^5
Students and professionals in mathematics, particularly those studying calculus, as well as educators seeking to clarify the concept of inflection points and their conditions.
jd12345
Well i know that an inflection point is where the curve changes its concavity.
But i don't really understand the conditions for it.
It says that second derivative should be zero(but that's not sufficient). I understand this. Second derivative being zero is not sufficient, example is y =x^4. So further condition is that some of the following odd derivatives should be zero which i don't understand
What's with the odd derivative? I don't get the intuition
concavity is measured buy the sign of the second derivative, so changing concavity means the second derivative changes sign.
If the second derivative changes sign at c, then in particular it has to be zero at c (if it exists there), but not vice versa. But if the third derivative is non zero at c, then the second derivative was either increasing or decreasing at c. Thus if the second derivative was zero at c and also the third derivative was not zero, then the second derivative must have changed sign...the same game goes on...A simple illustration is to think of the Taylor series. Your curve looks locally like the lowest non zero term of the Taylor series. So If the 5th derivative is the first non zero derivative then your curve looks like y = x^5, which has an inflection point,
but if the first non zero derivative is the 6th, then your curve looks like y = x^6, which has no inflection point.
  • · Replies 22 ·
