| New Reply |
Power, Work and Friction Problem! |
Share Thread | Thread Tools |
| May9-12, 07:03 PM | #1 |
1, How much power is needed to push a 90 kg chest at 0.52 m/s along a horizontal floor where the coefficient of friction is 0.79? 2, How much work is done in pushing the chest 9.0m? 2. Relevant equations Unsure sorry. 3. The attempt at a solution I'm lost on how to solve either of these; but I do know that the answer to question 1 is 360 Watts. Don't know how it was found though.... |
| May9-12, 07:11 PM | #2 |
P= W/change in time
Since work= Fd, P=Fd/change in t= FVav So then plug everything in for Power= Force x Average Velocity For part 2, the normal force is just 90 is just perpendicular to the surface so plug in the numbers into Work = Force x Distance once you solve for distance. |
| May9-12, 07:46 PM | #3 |
Awesome, thank you!
But one more question.. How do I find that first force if force=mass x acceleration, but the velocity is constant for the object? |
| May10-12, 12:49 AM | #4 |
The Net force is zero when the velocity is constant, therefore there would be no acceleration. The only forces acting on the crate is the Normal force and gravity which cancel, and Force of friction, so just use that as your force. When you push it with contact, there is a force applied, but once you let go the only unbalanced force is friction. Since there is friction, the box would eventually come to a stop therefore the velocity wouldn't be constant as it slides, or it will slide on forever.
| New Reply |
| Tags |
| friction, power, work |
| Thread Tools | |
Similar Threads for: Power, Work and Friction Problem!
| Work and Kinetic Energy Problem involving friction hw problem, DUE SOON | Introductory Physics Homework | 1 | ||
| Work and Power of the Friction Force in an F=-bυ damped oscillation | Classical Physics | 5 | ||
| Work, Energy and Power (Work Problem) | Introductory Physics Homework | 9 | ||
| Work problem with friction | Introductory Physics Homework | 1 | ||
| Friction and Power Problem | Introductory Physics Homework | 2 | ||
