New Reply
designing of a steam power plant
Share Thread Thread Tools
May10-12, 02:06 AM   #1
electric power = one million kW
working fluid = steam
maximum steam temperature = 550°C
river mean speed = 10m/min
river,8m deep,60 meter wide
2. Relevant equations
It is proposed to build a one million kW electric power plant with steam as the working fluid. The condensers are to be cooled with river water (see figure below). The maximum steam temperature will be 550°C. As an engineering consultant, you are to convince the authorities that the discharge to the river will not be harmful to the environment.
3. The attempt at a solution
this question may have several answer
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Ants and carnivorous plants conspire for mutualistic feeding
>> Forecast for Titan: Wild weather could be ahead
>> Researchers stitch defects into the world's thinnest semiconductor
May10-12, 09:02 AM   #2
Recognitions:
Homework Helper Homework Help
Well what is the range of temperatures can the heated water enter the river again at? (35C? Also what the exit condition of the steam turbine? Vacuum/Back pressure? If so you will need that pressure condition.
May11-12, 04:12 AM   #3
Recognitions:
Gold Membership Gold Member
Initial assumptions:
1. Carnot efficiency
2. River entering temperature Tin
Then:
1st equation: 1st law expressed in time-derivative form
2nd equation: 2nd law expressed in time-derivative form
Third equation: temperature buildup of river water as function of dm/dt, c and dQ2/dt where dQ2/dt is rate of expelled heat into river, dm/dt = rate of water mass flow, c = water specific heat, J/C-kg.
So: 3 knowns: dW/dt = 1 MW, T1 = 550C, Tin
3 unknowns: dQ1/dt, dQ2/dt, ΔT
where dQ1/dt = heat rate into system and ΔT = Tout - Tin = temperature rise of river water.
Assume T2, the effective lower temperature in the Carnot cycle, is halfway between Tin and Tout, i.e. T2 = (Tin + Tout)/2.
Finally, you must do some research to find what the typical steam-generated electric plant mechanical efficiency is beyond the Carnot efficiency.
May11-12, 10:21 PM   #4
the the range of temperatures is 6c that is between 32-38c
thanks guys...i will try to finish it up.
New Reply
Tags
design, power plant, river
Thread Tools
Similar Threads for: designing of a steam power plant
Thread Forum Replies
Designing a power plant cycle Engineering, Comp Sci, & Technology Homework 0
Steam Power Plant Engineering, Comp Sci, & Technology Homework 2
Steam Power Plant Cycle Mechanical Engineering 7
