Value that this series converges to
  • Thread starter Thread starter ladyzzyzzyzzx
    Series Value
The discussion revolves around the convergence of the series Ʃ4/(n^2-1) starting from n=2. Participants are exploring the implications of various convergence tests and the nature of the series itself.
  • Participants discuss the use of the ratio test and the test for divergence, questioning their conclusions and applicability. There is a focus on understanding what it means for a series to converge or diverge based on the behavior of its terms as n approaches infinity.
The conversation includes attempts to clarify the nature of the series and the tests being applied. Some participants have provided guidance on identifying the series as telescoping, while others have raised questions about the validity of certain reasoning regarding convergence.
There is a mention of potential confusion regarding the notation used for the series, which may affect the interpretation of the convergence tests applied. Additionally, the limitations of the test for divergence are being examined, particularly its inability to confirm convergence.
ladyzzyzzyzzx
Ʃ4/(n^2-1) n=2
Need help trying to solve it. I've used other tests like the ratio test and they have all resulted inconclusive.
It does converge because the Lim as n→∞ equals 0. Do not know where to go from here. Some help would be nice! Thank you!
Could you tell me the name of the test that gives this conclusion?
it was a test for divergence, i was told if the lim n→∞ of an ≠ 0 then it diverges
Does this test ever tell you that a series converges?
not explicitly, but if it does not diverge then i am assuming it must converge
Well it's a common misconception, so don't feel bad. But the test for divergence is not always conclusive (in fact it often isn't). It only singles out series that don't meet the minimum requirement for convergence. It's kind of like an entrance exam; you got to pass it to get in, but it's no guarantee that you're going to be successful.
So bottom line, the test for divergence only tells you that a series diverges. It never tells you when a series doesn't diverge (i.e. it never tells you that a series is convergent).
Look at the harmonic series for a stock counterexample to the kind of reasoning you tried to use.
As far as your problem goes, if I tell you that you've got yourself a telescoping series, is that enough to get you going?
yes actually, thank you! i just needed a direction :)
Good.
Now as far as having a good strategy heading into these kinds of problems (so this isn't about math, really; it's about problems you run across in math classes):
There are basically only two elementary ways that we can find the values of convergent series (remember the tests only tell you, when they're conclusive, whether or not a series converges/diverges. they don't tell you what it converges to). (1) Compute the limit of the partial sums and (2) get clever with some tricks with Power Series (don't worry if you haven't seen them). The kinds of series whose partial sums we can compute so that we can take a limit are essentially the geometric series (for which we have a formula) and telescoping series.
So if you have a problem that asks you to compute the value of a convergent series, there's a real good chance that it's either a geometric series or a telescoping series. Geometric series are relatively easy to identify, so ...
ladyzzyzzyzzx said:
Ʃ4/(n^2-1) n=2
Your notation is unclear: is your series supposed to be
[tex]\sum \frac{4}{n^2-1} n = \sum \frac{4n}{n^2-1}, \text{ or is it }<br /> \sum \frac{4}{(n^2-1)n}?[/tex]
If you mean the former, you have more-or-less written it correctly already (reading your expression according to standard priority rules), but if you mean the latter, you should use parentheses, like this: Ʃ4/[(n^2-1)n].
Assuming you mean the latter: your argument about the series converging because the nth term --> 0 is patently *false* (that is, the argument is false, not necessarily the conclusion). Lots of divergent series have terms that --> 0; it is just that they do not --> 0 fast enough. That is the issue you must decide.
RGV
