Is it possible to create a SINGLE circular wave?
  • Context: Undergrad
  • Thread starter Thread starter titaniumpen
    Circular Wave
The discussion centers on the feasibility of creating a single circular wave in a ripple tank, highlighting the challenges associated with generating such a wave. Participants agree that while it is theoretically possible to create a wave with a prominent peak followed by smaller peaks, achieving a perfect single circular wave is impractical due to the need for a complex combination of frequencies. A proposed method involves using a circular disk with a central ring to initiate a wave, but concerns remain about the wave's tendency to broaden over time.
  • Understanding of wave mechanics and properties
  • Familiarity with ripple tank experiments
  • Knowledge of frequency combinations in wave generation
  • Basic principles of surface tension in fluids
  • Research wave interference patterns in ripple tanks
  • Explore methods for generating controlled waveforms in fluid dynamics
  • Investigate the effects of surface tension on wave propagation
  • Study the mathematical modeling of waveforms using Fourier analysis
Students and educators in physics, fluid dynamics researchers, and hobbyists interested in wave behavior and ripple tank experiments.
titaniumpen
Just thinking, when you drop a single drop of water into a body of water you get ripples, not a single ripple. That's because the water at the contact point goes up and down. Is it possible to create a single circular wave? That will make it easier to observe the behavior of a single wave in a ripple tank, without being confused by interference.
No. But almost. It would be very complicated to make since it would have to be a combinations of a very large number of frequencies. But you could, technically, create a wave that had one very large peak followed by very, very small peaks.
AM
Here is what comes to me as a possible way.
Take a circular disk with a little ring attached to it at the center, so you can pull the disk by the ring.
Now put the disk on a still water. Pull the disk a little bit so it lifts slightly, while still being in contact with the water (due to surface tension). Now release the disk suddenly. The rim of the disk will initiate a circular wave and it is possible that its front would be thin, as the water under disk can't wave afterwards.
I haven't tried it, it's just a guess, but I think up to 75% it may work.
One problem is, that even if this method worked, unless one created a really big splash like tsunami, the wave would have thin front only in the first instant, and will spread afterwards into broad waves afterwards.
  • · Replies 17 ·
  • · Replies 33 ·
  • · Replies 36 ·
10K
  • · Replies 21 ·
