New Reply
Oscillating pressure regulation system
Share Thread Thread Tools
May13-12, 04:17 AM   #1
Hi all,
I'm after a water system involving some sort of pressure valve (pressure regulator, relief valve etc - whichever gets the job done) where the inlet pressure is always OVER set-pressure, and the valve oscillates (opens and closes rapidly) in response. It is this oscillation that is desirable in my case :)
I am hoping for some sort of system that:
- Water flows through system
- Inlet water pressure builds up to be higher than set-pressure
- Valve opens (etc) that dumps inlet pressure
- In response to the lowered inlet pressure the valve closes again
- Process repeats ad infinitum at a fast rate to oscillate the valve
I am not concerned by the output. I am simply dumping the water.
Does a relief valve work like this by default?
If not, does any body know of a valve, or a modification to a valve, that will produce this property?
Thanks in advance!
Peter
PhysOrg.com
PhysOrg
engineering news on PhysOrg.com
>> Researchers use light projector and single-pixel detectors to create 3-D images
>> GPS solution provides 3-minute tsunami alerts
>> Single-pixel power: Scientists make 3-D images without a camera
May15-12, 12:53 AM   #2
Quote by Projectitis View Post
Hi all,
Thanks in advance!
Peter
A relief valve will get the job done. It does work like that by default.
-Jeff
May15-12, 09:46 AM   #3
Don't expect great accuracy though. Also, what sort of volume are you looking to dump?
May15-12, 04:02 PM   #4
Thanks guys. The volume of water is not important - I am after the highest rate of oscillation I can get. I'm guessing I just need to tune the system so that the set pressure is much lower than the input pressure, but not too low to keep the valve open.
New Reply
Tags
porv, posrv, prv, psv, valve
Thread Tools
Similar Threads for: Oscillating pressure regulation system
Thread Forum Replies
oscillating, hanging spring-block system Introductory Physics Homework 5
oscillating system stability Classical Physics 3
Design with Springs in an Oscillating System Mechanical Engineering 0
Energy of an oscillating system Introductory Physics Homework 9
