Autonomous Differential Equations: Equilibrium Solution and Deviation Equation
  • Thread starter Thread starter Townsend
The problem involves analyzing a differential equation of the form dy/dt = ay - b, specifically focusing on finding the equilibrium solution and the deviation from that solution. The subject area is differential equations, particularly autonomous equations and their equilibrium points.
  • The original poster attempts to clarify the meaning of the equilibrium solution y_e and expresses confusion regarding its determination based on the parameter a. Some participants question the assumptions made about the behavior of the solution as t approaches infinity, particularly whether a must be negative for equilibrium to exist. Others suggest that the general solution should not diverge and explore the implications of different values of a on the equilibrium solution.
Participants are actively engaging with the problem, with some providing insights into the conditions under which equilibrium solutions exist. There is a recognition of the need to clarify the definitions and implications of the terms used in the problem. Multiple interpretations of the equilibrium solution and its derivation are being explored, indicating a productive direction in the discussion.
There is an ongoing discussion about the assumptions regarding the parameter a and its effect on the equilibrium solution. Participants are also considering the implications of the general solution's behavior as time progresses, which may affect the interpretation of the problem.
Townsend
The problem is
Consider the differential equation [tex]dy/dt=ay-b[/tex].
a) Find the equilibrium solution [tex]y_e[/tex].
b)Let [tex]Y(t)=y-y_e[/tex]; thus [tex]Y(t)[/tex] is the deviation from the equilbrium solution. Find the differential equation satisfied by [tex]Y(t)[/tex].
For part a I am confused as to what is meant by [tex]y_e[/tex].
The general solution is
[tex]y=Ce^{at}+\frac{b}{a}[/tex]
I thought that the equilibrium is just the value that will be approached as t increases without bound. So in this case it depends on the values of a. If a>0 then there is no equilibruim solution. How can I answer part a then?
So without anywhere to go I made the assumption that [tex]y_e[/tex] is meant to mean the [tex]y(e)=y_e[/tex] in which case I come up with.
[tex]Ce^{ae}+\frac{b}{a}=y_e[/tex]
So if this in fact the equilibrium solution [tex]y_e[/tex] then for part b I have
[tex]Y(t)=Ce^{at}+\frac{b}{a}-\left( Ce^{ae}+\frac{b}{a} \right)[/tex]
[tex]Y(t)=ce^{at}-ce^{ae}[/tex]
Which is really like any our first diff eq but in this case the [tex]\frac{b}{a}=-ce^{ae}[/tex] But the constant C makes our value for b/a unknown. Obviously I have something wrong here and I think its because I do not understand what the question is really asking.
Thanks for any help
This part
is definitely wrong.You made a point.The general solution to the equation
[tex]y(x)=Ce^{at}-\frac{b}{a}[/tex]
must not diverge for asymptotic behavior...Which means that "a" must be negative...Find the equilibrium solution and then the function expressing the "deviation" from equilibrium...
Daniel.
PS.The diff.eq. will b very simple...
Ok, well if know that a<0 then the equilibruim is going to be [tex]\frac{b}{a}[/tex]
So then [tex]Y(t)=Ce^{at}[/tex]
and
[tex]\frac{dY}{dt}=ay[/tex]
You said the diff.eq. will be b,I am not sure how you got that.
sorry, I am trying to understand.
Thanks
That "b" was "be"... :-p You got the picture. :smile: The diff.eq.may be put under the form which would definitely show the asymptotic behavior,namely make the substitution
[tex]a\rightarrow -|a|[/tex]
Daniel.
