Thermal gradients in electrical paths of thermocouple conductors
The discussion focuses on the challenges of measuring temperature accurately using thermocouples (d- and k-type) in a high-pressure, high-temperature environment. The setup involves tungsten carbide cylinders and press-fitted steel rings, which may cause thermal gradients affecting voltage readings. The user expresses concern that differing temperatures along the electrical paths of conductors A and B could introduce inaccuracies in temperature measurements. Suggestions for improving measurement accuracy in this context are sought from the community.
  • Understanding of thermocouple types (d- and k-type)
  • Knowledge of thermal gradients and their effects on electrical measurements
  • Familiarity with high-pressure and high-temperature measurement environments
  • Basic principles of electrical noise and signal integrity
  • Research methods to minimize thermal gradients in thermocouple setups
  • Explore the use of differential thermocouple configurations
  • Investigate noise reduction techniques in electrical measurement systems
  • Learn about calibration techniques for thermocouples in challenging environments
This discussion is beneficial for engineers, temperature measurement specialists, and technicians working with thermocouples in high-pressure and high-temperature applications, particularly those seeking to enhance measurement accuracy and reduce electrical noise.
erichp
I recently inherited a problem related to temperature measurement.
Thermcouples (d- and k- type) are being used in a high-pressure, high-temperature environment, with the measuring junction suspended in an electrically-insulating solid. The leads of conductors A and B extend out of the solid and, each is held in contact with a separate tungsten carbide cylinder. Around each cylinder, there is a press-fitted steel ring. From that steel ring, wires lead to the instrument where voltages are compared.
I realize this setup is non-ideal for several reasons, but the one I'm most concerned about is this: Each cylinder system is liquid cooled, and it's possible that the temperature at a given point on cylinder A is different than the temperature at the corresponding point on cylinder B. I'm concerned that the difference in temperatures along the electrical paths could alter voltages and lead to inaccurate temperature measurements.
Has anybody dealt with anything similar? Do you have suggestions that can help me get accurate temperature measurements?
Please forgive my ignorance on the topic - if more information is required, please let me know.
I think the wires going separately gather unwanted signals - the "noise" .
  • · Replies 0 ·
  • · Replies 152 ·
12K
  • · Replies 16 ·
15K
