New Reply
2D Momentum Problem
Share Thread Thread Tools
May16-12, 06:08 PM   #1
2D Momentum Problem
Car 1 weighing 1000 kg crashes into the rear of parked car 2 weighing 1100 kg and stops. Car2 moves ahead 2 ms2. What is the velocity of car1 at impact?
2. Relevant equations
(m1v1+m2v2)=(m1v3+m2v4)
3. The attempt at a solution
(m2V4)/m1
(1100*2)/1000
2.2ms2= 2200/1000
Okay, now I know this is right, but what I don't know is how do they arrive at the equation (m2v4)/m1 ????
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Bird's playlist could signal mental strengths and weaknesses
>> Minus environment, patterns still emerge: Computational study tracks E. coli cells' regulatory mechanisms
>> Bacterium uses natural 'thermometer' to trigger diarrheal disease, scientists find
May16-12, 06:53 PM   #2
Quote by Probie1 View Post
(m2V4)/m1
(1100*2)/1000
2.2ms2= 2200/1000
If you examine your original conservation of momentum equation, let [itex]v_1, v_3[/itex] be the initial and final speeds of car 1, respectively, and let [itex]v_2,v_4[/itex] be the initial and final speeds of car 2, respectively. From the context of the problem, what must be true about speeds [itex]v_2[/itex] and [itex]v_3[/itex]?
May17-12, 04:10 PM   #3
(1000*2.2+1100*0)=(1000*0+1100*2)
V2 and v3 have no velocity so they have no momentum...correct?
May17-12, 04:35 PM   #4
2D Momentum Problem
Correct.
May17-12, 04:55 PM   #5
So because they have no momentum they cancel out which means you rewrite the equation to solve for velocity1
(1000)=(1100*2)
(m1)=(m2v4)
(m2V4)/m1
(1100*2)/1000
2.2ms2= 2200/1000
Is that how it is done?
May17-12, 04:56 PM   #6
Yes, that's the idea. Conservation of momentum dictates [itex]m_1 v_1 = m_2 v_4[/itex], solving for the initial speed is just an algebra problem.
May17-12, 05:01 PM   #7
Thanks Steely Dan... that wasn't as hard as I thought it would be... mind you that was an easy momentum problem for you, but difficult for me. I imagine it would be harder if you had 1 vehcile t-bone another and they both have pre and post impact velocities.
May17-12, 05:18 PM   #8
I was just re reading your posts...
Yes, that's the idea. Conservation of momentum dictates m 1 v 1 =m 2 v 4 , solving for the initial speed is just an algebra problem.
...when I re read this post the light started to flicker.
Thanks again Steely Dan
New Reply
Thread Tools
Similar Threads for: 2D Momentum Problem
Thread Forum Replies
Angular momentum: why can't I answer this problem using linear momentum rules? Introductory Physics Homework 2
Momentum, conservation of linear momentum problem Introductory Physics Homework 1
Momentum and Conservation of Momentum Problem Introductory Physics Homework 11
momentum problem Introductory Physics Homework 3
Momentum / Angular Momentum Problem Introductory Physics Homework 0
