Find Coefficient of X^5 in (3x^3 - 1/x^2)^10
  • Thread starter Thread starter footprints
    Binomial Expansion
The problem involves finding the coefficient of the term \(x^5\) in the expansion of \((3x^3 - \frac{1}{x^2})^{10}\). This falls under the subject area of algebra, specifically binomial expansion and polynomial manipulation.
  • Exploratory, Mathematical reasoning
  • Participants discuss the general term in a binomial expansion and suggest substituting specific values for \(x\) and \(y\). There are also inquiries about completing the square and its application in a different problem involving a quadratic function.
The discussion includes various approaches to both problems presented. Some participants are exploring the binomial expansion while others are considering methods for finding minimum points of a quadratic function. Guidance has been offered regarding completing the square and the relevance of calculus, though there is no explicit consensus on the best approach.
Participants express uncertainty about specific mathematical techniques, such as completing the square and the use of calculus, indicating a range of familiarity with the concepts involved.
footprints
Find the coefficient of the term X^5 of the expansion
[tex](3x^3 - \frac{1}{x^2})^{10}[/tex]
Another question off the topic.
Find the x-coordinate of the minimium point of [tex]y=2x^2-5x+3[/tex]
I know I have to complete the square but I'm not sure how its done.
Can you write the general term in the expansion of (x+y)^n? If you can, then you can replace x by 3x^3 and y by (-1/x^2).
For the second question, completing the square is a good idea if you do not know calculus (or are not supposed to use it).
Why not show your solution first?
I know calculus. So how do I do it using calculus?
Do you know the First and Second Derivative Tests?
What happens to a continuous function when its derivative switches sign? By a theorem called the Intermediate Value Theorem, every function which switches sign at least once over an interval must attain the value zero.
Try sketching a graph to convince yourself about the behavior of your quadratic polynomial.
At this point, you should consult your Calculus textbook for the First and Second Derivative Tests. If you have a problem, I'd be glad to help further.
Cheers
Vivek
Nope. Never heard of that.
Okay,forget about calculus.This is elementary.Take the previous advice to complete the square.
As for the first problem:The general term in the binomial expasion is
[tex]C_{n}^{k}a^{k}b^{n-k}[/tex]
Daniel.
But I forgot how to complete the square. :redface:
[tex]ax^{2}+bx+c=a(x^{2}+\frac{b}{a}x)+c=a[x^{2}+2\cdot (\frac{b}{2a})\cdot x+(\frac{b}{2a})^{2}]+c-a(\frac{b}{2a})^{2}=a(x+\frac{b}{2a})^{2}+c-\frac{b^{2}}{4a}[/tex]
Apply it.
Daniel.
Thanks for the help!
You're welcome.I hope you will master "completing the square",eventually... :smile:
Daniel.
P.S.It would be embarrasing to use calculus to find the maximum/minimum of a parabola... :rolleyes:
I couldn't agree more...but you know its way faster than completing the square (you can write the answer by inspection and this is an asset if you're in a hurry). Nevertheless, its embarrasing :-p.
  • · Replies 18 ·
