New Reply
Unit Conversion: Astronomical Units, Parsecs and Light Years...
Share Thread
May17-12, 11:42 AM   #1
Hi everyone,
It's been years since I solved a physics problem for school. Now that I'm back at it I could use some help on this problem:
Question
"The astonomical unit (AU) is defined as the mean centre to centre distance from Earth to the Sun, namely 1.496 x 10^11 m. The parsec is the radius of a circle for which a central angle of 1s intercepts an arc of length 1AU. The light year is the distance that light travels in 1 year. (a) How many parsecs are there in one AU?
The attempt at a solution
I can do simple conversions of units, but I'm having trouble figuring out the connection between AUs and parsecs. I know that Arc length = r * angle (in rad) which leaves me with 1 AU = 1 parsec * 1s. But then again s is seconds, not radians...
Another way I attempted the problem was to assume that the arc of a circle whose radian is 1 parsec is so large that I can assume that the arc is a straight line, is that a fair assumption?
I'd really appreciate any corrections or just a hint in the right direction, not the full answer, and then hopefully I can work out the other parts of the problem myself. Thank you in advance!
PhysOrg.com science news on PhysOrg.com
>> Leading 3-D printer firms to merge in $403M deal (Update)
>> LA to give every student an iPad; $30M order
>> CIA faulted for choosing Amazon over IBM on cloud contract
May17-12, 11:50 AM   #2
Recognitions:
Homework Helper Homework Help
Quote by iwantpi View Post
Hi everyone,
Question
Hi iwantpi, Welcome to Physics Forums.
The '1s' above is 1 arc second, an angle. Remember that degrees are divided up into 60 arcminutes, which are in turn divided into 60 arcseconds.
May20-12, 10:51 PM   #3
1 parsec = 206264.984626 au
I got it from aconverter.net, which I usually used. hope this help.
Jun15-12, 12:08 AM   #4
Thanks for all the help you two and sorry bout the late reply. I figured it out. It wasn't so hard once you guys told me about the arc second thing. Thanks again.
New Reply
Tags
astronomical units, conversion, parsecs, units
Similar discussions for: Unit Conversion: Astronomical Units, Parsecs and Light Years...
Thread Forum Replies
Units in Rings: show 1-ab a unit <=> 1-ba a unit Calculus & Beyond Homework 1
Instantaneous Unit Conversion between CGS and SI units General Math 2
Converting units for Mass Estimates of Astronomical bodies Astrophysics 0
Parsecs, trigonometric parallax and light years! General Astronomy 4
converting parsecs to Mega-parsecs Astrophysics 1
