How Does Resistance Distribute Along the Length of a Resistor?
  • Thread starter Thread starter Physicslearner500039
    Element Resistance
The discussion revolves around the distribution of resistance and voltage drop along the length of a resistor. Participants explore whether resistance increases from one end of the resistor to the other or remains constant, and how this relates to the voltage drop when current flows through the resistor. The scope includes conceptual clarification and technical explanation.
  • One participant questions if the resistance increases from 0 at the beginning to R at the end of the resistor, or if it is constant throughout its length.
  • Another participant suggests that if the material is uniform, the resistance is constant, but notes that in wire wound resistors, resistance can increase in steps.
  • A participant proposes that the voltage drop across a resistor can be viewed as the sum of small voltage drops across its segments.
  • One response affirms that small parts of a resistor can be treated as small resistors in series, contributing to the total voltage drop.
  • Another participant argues that the resistance does not increase from 0 to R, asserting that it is constant along the entire length of the resistor and that the voltage drop is also constant at any point along it.
  • This participant uses an analogy comparing resistance to the diameter of a pipe, suggesting that resistance remains the same throughout the length of the resistor.
There is no consensus on whether resistance varies along the length of the resistor. Some participants propose that resistance is constant, while others suggest it can vary depending on the type of resistor. The discussion remains unresolved regarding the nature of resistance distribution.
Participants express different views on the behavior of resistance and voltage drop, highlighting the dependence on the type of resistor and its material properties. The discussion includes assumptions about uniformity and the nature of resistive elements.
Hi All,
I have this clarification, if I have a resistor element of any value and if the physical length of the resistor is say L. Does the resistance of the element increases from 0 at the beginning to R at the end of the resistive element that is L, or it is the average, or it is located at one point, could somebody please explain me this? Similarly if a current I is flowing through the resistive element the voltage drop say Vr keeps increasing from 0 to the Vr at the end of the element or how it is?
Thanks in advance,
regards,
Satya
It depends on the resistor, but if the resistance material is uniform, then this is true:
Wire wound resistors are similar, but the resistance increases in steps as you go from turn to turn. If you followed the wire all the way around the resistor, then the resistance increases as you go from one end to the other.
There are potentiometers of both types which allow you to connect to various ponts on a resistor and gradually change the resistance or the ratio of resistances..
So can I say that a voltage drop across a resistor (by passing a current) is the sum of the small voltage drops within the resistor ?
Thanks in advance,
Regards,
Satya
Yes, you could say that.
The small parts of a resistor are just like having a lot of small resistors in series, so you could regard each of them as producing a small voltage due to the current flowing in it.
Hello Satya,
The resistance of an element is a measure of its ability to resist the flow of current. It is typically represented by the letter R and is measured in ohms (Ω). The resistance of an element is determined by its physical characteristics, such as length, cross-sectional area, and material composition.
In the case of a resistor element, the resistance does not increase from 0 at the beginning to R at the end. Rather, the resistance is constant throughout the entire length of the element. This means that the voltage drop across the element is also constant, regardless of where it is measured along the element's length. Therefore, the voltage drop Vr at the end of the element is the same as the voltage drop at any other point along the element.
To understand this concept, it may be helpful to think of a resistor element as a pipe through which water (current) flows. The resistance is like the diameter of the pipe - a wider pipe will allow more water to flow through at a given pressure (voltage). However, the resistance remains the same throughout the entire length of the pipe.
I hope this helps clarify your question. Please let me know if you have any further questions.
Best,
  • · Replies 50 ·
  • · Replies 60 ·
