Why Phone Charger Makes High Frequency Sound
The discussion revolves around the phenomenon of a phone charger emitting a high-frequency sound when plugged in, exploring potential causes and implications. Participants examine the technical aspects of charger operation, including energy loss, internal vibrations, and electromagnetic interference.
  • One participant notes that phone chargers typically use switching regulators that oscillate at tens of kilohertz, which may cause audible noise if the transformer vibrates.
  • Another participant questions whether there is current flow and energy loss even when the charger is not connected to a phone.
  • It is suggested that the high-frequency sound could be due to internal components of the charger vibrating during the conversion of AC to DC current.
  • Electromagnetic interference (EMI) is proposed as another possible cause, particularly when the phone is connected and drawing power, leading to increased electrical activity.
  • A potential concern is raised regarding faulty or damaged components within the charger, which could pose safety hazards if the sound becomes louder or more frequent.
Participants present multiple competing views on the causes of the sound, with no consensus reached regarding the primary reason or implications of the phenomenon.
Some assumptions about the charger's design and operation are not explicitly stated, and the discussion does not resolve the specifics of energy loss or the implications of electromagnetic interference.
bilal j
Hi. I noticed that my phone charger (output: 5V DC) makes a constant high pitched noise when plugged into the wall. It's not too loud but you can hear it when you are within maybe 4 ft of the charger. When I plug my phone in, it starts making intermittent noises. I was wondering what this could be caused by?
Most charges are using switching regulators, they oscillates in 10s of KHz, you can hear it if the transformer buzzes.
does that mean there is current flow and thus energy loss even without the phone attached?
Yes, there is always a little loss if you keep the charger plugged in.
There are a few potential reasons why your phone charger is making a high frequency sound. One possibility is that it is due to the internal components of the charger vibrating at a high frequency. This can happen when the charger is converting the AC current from the wall outlet into the DC current that is needed to charge your phone. The process of converting the current can create small vibrations within the charger, which can produce a high pitched sound.
Another potential cause could be electromagnetic interference (EMI). This occurs when the electrical signals within the charger interact with other electronic devices or components, causing them to vibrate and produce sound. This can be more noticeable when your phone is plugged in and drawing power from the charger, as it can create more electrical activity and potential for interference.
Additionally, it is also possible that the sound is being produced by a faulty or damaged component within the charger. If this is the case, it is important to stop using the charger and have it checked by a professional to avoid any potential safety hazards.
Overall, the high frequency sound from your phone charger is likely due to the internal components vibrating or EMI, which are common occurrences in electronic devices. However, if the sound becomes louder or more frequent, it is recommended to have the charger inspected to ensure safe and proper functioning.
13K
  • · Replies 24 ·
