Statics problem about an anchored plank in water
  • Thread starter Thread starter vanillin
    Statics Water
The discussion revolves around a statics problem involving an anchored plank submerged in water. Participants are exploring the forces acting on the plank, including tension, gravitational force, and buoyancy, while considering the conditions for equilibrium.
  • Participants discuss the equilibrium conditions, noting that both net force and torque are zero. There are attempts to express forces in terms of density and volume, and questions arise regarding the distances and angles involved in the torque calculations. Some participants express frustration over the complexity of the problem and seek guidance on the steps to take.
Hints have been provided regarding the computation of the center of pressure and the enforcement of equilibrium through moment summation. Some participants are actively engaging with the problem, while others express a desire for more structured guidance without seeking complete solutions.
Participants mention constraints such as limited time and the need to adhere to forum rules regarding the provision of complete solutions. There is also a recognition that certain variables, like volume, may cancel out in the equations, but participants are still grappling with how to manipulate the equations effectively.
vanillin
Hello, I'm new and quite unfamiliar with all the conventions, but I'll use underline for vectors since I couldn't find the proper thing (is the convention to use bold here?)
Problem:
No more.Relevant equations:
Fnet = ma = 0
τnet = Iα = 0
τ = r x F = rFsinθ
Fbuoyancy = ρwaterVgAttempt at solving:
What I realized is that since the plank isn't in translational nor rotational motion, the net force and torque are both zero. T = tension, G = gravitational f., B = buoyancy.
T + G + B = 0
in scalar:
T + G - B = 0
Also, I know how to equate the torques (only gravity and buoyancy cause torque), but I can't find out the distances nor angles. I can also express the gravitational force in terms of density of the plank and it's volume...? Things just don't cancel out neatly there.
I can provide a diagram if really necessary, but I'd prefer not to now, I have very limited time. Thanks in advance. Also, is the template there to be followed rigorously or is any kind of organised posting viable?
Hint:
Compute center of pressure as a function of angle and enforce equilibrium using moment summation.
LawrenceC said:
Hint:
I would really like to have a solution given, or at least all the steps necessary, because I've been fighting with this for a good while and I don't feel like anymore, as it's not the only thing I need to know for Wednesday.
If nobody gives me the answer before tomorrow, I might try it then... but I would really appreciate a solution, as I've tried to do this.
E: Just noticed that complete solutions violate the rules... well is it possible to at least give me the steps, and I could do them myself?
Find the upward force due to the portion under water as a function of the angle and the distance from the surface. That force is directed vertically and is applied at the center of gravity of the portion under water. This creates a moment. Determine the moment in the other direction due to its natural weight. The plank is in equilibrium so what do you know about the sum of the moments?
LawrenceC said:
Find the upward force due to the portion under water as a function of the angle and the distance from the surface. That force is directed vertically and is applied at the center of gravity of the portion under water. This creates a moment. Determine the moment in the other direction due to its natural weight. The plank is in equilibrium so what do you know about the sum of the moments.
L = length of plank
the angle θ between the forces and the moment arm is the same for both as the forces are only antiparallel.
B = ρwaterVsubmergedg
G = ρplankVplankg
V = ?
τB = rBsinθ = (L/2 - x) * ρwaterVsubmergedg sinθ
τG = rGsinθ = (L/2) * ρplankVplankg sinθ
(L/2 - x) * ρwVsubg sinθ = (L/2) * ρpVpg sinθ
→ (L/2 - x) * ρwVsub = (L/2) * ρpVp
Sum of the moments is zero, that I knew. I can identify all the forces and where they act, I just cannot make them into reasonable equations. Like volume, how do I get rid of it?
The volume consists to a cross section multiplied by length. The cross section is arbitrary but appears in each term so it cancels.
Oh, foolish me... I was stuck at the T + G - B = 0 with no hope of getting rid of V or A... had I only started with the moments.
Thanks, I think it makes sense now, I'll try it and see if I get the answer.
E: Yes, I got the answer, thank you. I think the angle is a matter of geometry.
  • · Replies 22 ·
  • · Replies 42 ·
  • · Replies 29 ·
